1. Accessing Pabbly Chatflow for Chatbot Creation
To create an AI chatbot, start by accessing Pabbly Chatflow. Open a new browser tab and navigate to pabbly.com/chatflow. This platform enables you to build chatbots without any coding knowledge.
Once on the Pabbly Chatflow homepage, you can sign up for a free trial. This allows you to explore the features without any initial cost. After signing up, log in to your Pabbly Chatflow account to access the dashboard.
2. Adding Your WhatsApp Number in Pabbly Chatflow
After logging into Pabbly Chatflow, the first step is to add your WhatsApp number. This is crucial as all chatbot interactions will occur through this number. Navigate to the settings and locate the option to add your WhatsApp number.
- Go to the settings section.
- Select the option to add your WhatsApp number.
- Follow the prompts to verify your number.
Once your number is added, you can proceed to create your AI assistant. This setup is essential for the chatbot to function effectively on WhatsApp.
3. Creating Your AI Assistant in Pabbly Chatflow
With your WhatsApp number set up, navigate to the AI assistant section in Pabbly Chatflow. Click on the “Add AI Assistant” button to start creating your chatbot. You will need to name your assistant; for example, you can name it “AI Chatbot”.
Next, select the instruction type. Choose “AI Agent” to allow the assistant to respond intelligently. You can adjust the temperature setting, which controls the creativity of responses. A lower temperature yields more focused answers, while a higher temperature allows for creative responses.
- Set the temperature to around 0.3 for focused responses.
- Choose OpenAI as the AI model.
- Input your OpenAI API key to connect.
After entering the API key, click on “Connect” to save the settings. Your AI assistant is now ready to start handling queries.
4. Uploading Knowledge Source for Accurate Responses
To ensure your AI chatbot can provide accurate answers, you need to upload a knowledge source in Pabbly Chatflow. This is done by clicking on the “Upload File” button in the knowledge source section. You must prepare a document containing all relevant information about your business.
It is recommended to create this document in TXT format for best results. Once your document is ready, upload it to the media library. After uploading, select the file and insert it into the knowledge base.
- Ensure the document includes FAQs and essential details.
- Upload the file and confirm it is added to your knowledge base.
- Verify the upload by checking the date and time of the file.
With the knowledge base in place, your AI chatbot can now provide specific answers to user queries.
5. Finalizing Chatbot Settings and Deployment
After setting up your AI assistant and knowledge base, it’s time to finalize the settings in Pabbly Chatflow. You can customize the appearance of your chatbot, including the header and footer messages. Make sure to enter the initial message that users will see when they start a conversation.
To deploy your chatbot, navigate to the embedded section in Pabbly Chatflow. Here, you will find a script that you can copy and paste onto your website. This will allow visitors to interact with your AI chatbot directly through WhatsApp.
- Customize the chatbot’s appearance to match your brand.
- Copy the provided script for embedding.
- Test the chatbot to ensure it responds correctly to user queries.
Your chatbot is now fully functional and ready to assist users with their inquiries.
In this tutorial, we learned how to create an AI chatbot using Pabbly Chatflow. By integrating WhatsApp and OpenAI API, you can provide accurate and personalized responses to users. This process enhances customer interaction and support for your business.
