1. Setting Up Pabbly Connect for Instagram Integration
To begin with, Pabbly Connect is the central platform that enables you to integrate various applications seamlessly. Start by signing up at pabblaby.com/connect if you haven’t already. Once signed up, you will receive 100 free tasks every month, which is perfect for testing your workflows.
After logging into your Pabbly Connect dashboard, click on the plus button to create a new workflow. You will need to name your workflow, which will be crucial for identifying it later. Once named, the trigger step will appear, allowing you to select the application that initiates the automation.
2. Integrating Instagram Lead Ads with Pabbly Connect
In this section, we will set up Instagram Lead Ads as the trigger for our workflow using Pabbly Connect. Select “Instagram Lead Ads” from the list of applications. Choose “New Lead Instant” as the event. Click on the connect button to establish a connection.
  • Select “Connect with Instagram Lead Ads”.
  • Ensure your Instagram account is linked to Facebook.
  • Choose the relevant Facebook page running your ads.
After selecting your page, choose the lead generation form you want to use. You can select the response format as simple, advanced, or raw depending on your needs. For this tutorial, we will choose the simple format and click on “Save and Send Test Request”.
3. Fetching Lead Data from Instagram
Once the test request is sent, Pabbly Connect will wait for a webhook response. To get this response, navigate to your Meta Developers account. Click on “Resources” and then select “Developer Tools”.
  • Select “Lead Ads Debug Tool”.
  • Choose the page and form you want to test.
  • Fill out the lead form and submit it.
After submitting the form, return to Pabbly Connect to check if the new lead data has been received. You should see the lead details populated in the workflow, confirming that the integration is working properly.
4. Generating AI Responses with OpenAI
Now that we have the lead data, the next step is to generate a personalized response using OpenAI through Pabbly Connect. Select “OpenAI” as your action application and choose “Generate Response using Text Input” as the event.
To connect OpenAI, you will need to enter your API key. Navigate to your OpenAI account, create a new secret key, and copy it. Paste this key into Pabbly Connect and save the connection.
  • Select the model you want to use, such as GPT-4.
  • Map the data received from Instagram, such as the first name and last name.
  • Set the background processing mode to immediate for real-time responses.
After mapping the data, click on “Save and Send Test Request” to test the AI response generation. You should receive a positive response with an AI-generated message.
5. Sending Messages via WhatsApp with Pabbly Chartflow
Finally, we will send the AI-generated message to the user’s WhatsApp using Pabbly Chartflow. Select “Pabbly Chartflow” as your action application and choose “Send Text Message” as the event.
To connect, you will need to enter your API token from the Pabbly dashboard. Once connected, you will map the recipient’s WhatsApp number and the AI-generated message.
  • Ensure the contact number is formatted correctly without the plus sign.
  • Test the message sending by entering a valid WhatsApp number.
Click on “Save and Send Test Request”. You should see a success status indicating that the message was sent successfully. Check your WhatsApp to see the AI-generated message received.
In this tutorial, we demonstrated how to automate responses for Instagram leads using Pabbly Connect, OpenAI, and WhatsApp. By following these steps, you can enhance your lead response time and improve customer engagement effectively.
