1. Accessing Pabbly Chatflow for Bulk WhatsApp Messaging
To begin your bulk WhatsApp messaging journey, you need to access Pabbly Chatflow. Start by navigating to pabbly.com/chatflow in your browser. This platform provides an integrated solution for sending WhatsApp messages in bulk.
If you are a new user, click on “Sign Up Free” to create an account. Existing users can simply log in. Once logged in, find Pabbly Chatflow within the Pabbly applications window and click on “Access Now” to reach the dashboard.
2. Setting Up Your Message Template in Pabbly Chatflow
Once you’re in the Pabbly Chatflow dashboard, the next step is to set up your message template. This is crucial for sending bulk messages without spam issues. Templates need to be pre-approved by Meta to ensure compliance.
  • Navigate to the “Templates” section in your dashboard.
  • Review your existing templates or create a new one.
  • Ensure your template is approved by Meta for WhatsApp messaging.
After setting up your template, you can proceed to the broadcast section. This allows you to send messages to multiple contacts at once, using your approved template to avoid spam issues.
3. Creating a Broadcast in Pabbly Chatflow
Now that you have your template ready, it’s time to create a broadcast using Pabbly Chatflow. Click on the “Create Broadcast” button on your dashboard. This feature allows you to send messages efficiently to your contacts.
When prompted, select the type of broadcast as a “Campaign Broadcast”. You can name your broadcast, for example, “New Launch”. Next, you will choose your audience. If you have a CSV file with contact data, you can upload it directly.
4. Importing Contacts and Scheduling Your Broadcast
To import contacts for your broadcast, you can upload a CSV file directly into Pabbly Chatflow. If your data is in Google Sheets, download it as a CSV file first. After uploading, click on the “Import” button to create a separate contact list.
Additionally, you have the option to optimize your audience by excluding contacts you do not wish to message. You can filter out contacts with whom you have an active chat window or exclude entire lists. Once your audience is set, you can schedule the broadcast.
  • Choose whether to send the message immediately or schedule it for later.
  • If scheduling, select a future date and time.
  • Activate automatic retries for failed messages if necessary.
After setting these parameters, click on “Create Broadcast” to finalize your setup. You will receive a notification once the broadcast is created successfully.
5. Testing and Sending Your Broadcast
Before sending your broadcast to all contacts, it’s essential to test it. Use the testing feature in Pabbly Chatflow to send a test message to your WhatsApp number. This ensures that the message appears correctly and that the template is functioning as intended.
After testing, you can proceed to send out your broadcast. If you opted to schedule it, ensure the date and time are set correctly. Once sent, you can monitor the broadcast statistics, including sent, delivered, and read messages.
By following these steps in Pabbly Chatflow, you can send bulk WhatsApp messages without falling into spam issues. The platform’s features streamline the process and ensure compliance with WhatsApp’s guidelines.
In this tutorial, we explored how to use Pabbly Chatflow for bulk WhatsApp messaging without spam issues. By following the outlined steps, you can efficiently reach your audience while maintaining compliance with messaging guidelines.
Utilizing Pabbly Chatflow ensures a seamless experience in managing your WhatsApp communications effectively.
