1. Accessing Pabbly Chatflow for Bulk WhatsApp Messaging
To start using Pabbly Chatflow for bulk WhatsApp messaging, visit pabby.com/chatflow in your browser. This will direct you to the Pabbly Chatflow homepage, where you can either sign up for free or log in if you already have an account.
Once logged in, navigate to the “All Pabbly Apps” section and click on “Access Now” under Pabbly Chatflow. This will take you to the dashboard where you can manage your WhatsApp integrations.
2. Connecting Your WhatsApp Number in Pabbly Chatflow
Before sending bulk messages, you need to connect your WhatsApp number within Pabbly Chatflow. This step is crucial as it establishes the communication channel for your messages. If you are unsure how to do this, refer to the tutorial available on the Pabbly YouTube channel.
Once connected, you can create message templates for your bulk messaging campaign. Make sure to have your message template approved by Meta to ensure successful delivery. This template will be used for all your messages.
- Navigate to the “Template” section in Pabbly Chatflow.
- Select an approved template to use for your broadcast.
With your WhatsApp number connected and your message template ready, you are now prepared to set up your broadcast campaign.
3. Setting Up Your Broadcast in Pabbly Chatflow
In this section, you will learn how to set up a broadcast campaign using Pabbly Chatflow. Start by navigating to the “Broadcast” section on your dashboard. Here, click on the “Add Broadcast” button to initiate the setup process.
You’ll be prompted to select a type of broadcast campaign. Choose the appropriate option and name your broadcast, for example, “New Launch”. Next, you will need to select your audience. You can either upload a CSV file or choose from an existing contact list.
- Select “Existing Contact List” if you already have contacts.
- Upload a CSV file if your contacts are in another database.
Once your audience is set, you can refine your audience by excluding specific contacts if necessary. This allows for a targeted messaging approach.
4. Composing Your Message in Pabbly Chatflow
After setting up your broadcast audience, it’s time to compose your message using Pabbly Chatflow. You will have options to send a regular message or use a pre-approved template. Since you have already created a template, select it from the drop-down menu.
Additionally, you can personalize your message by adding variables. For instance, you can include the recipient’s name for a more engaging experience. Once your message is composed, you can test it by sending a test message to your own WhatsApp number.
- Select your message type from the options available.
- Click on “Send Test Message” to ensure everything works correctly.
Once you confirm that the test message is received successfully, you can proceed to schedule or send your broadcast.
5. Scheduling Your Broadcast in Pabbly Chatflow
Now that your message is ready, you can schedule your broadcast using Pabbly Chatflow. You have the option to send the message immediately or schedule it for a later date and time. If you choose to schedule, ensure you select a future date and time to avoid sending it instantly.
Additionally, you can enable automatic retries for failed contacts. This feature allows you to resend messages to contacts who didn’t receive them on the first attempt. Specify the number of retries and the wait time between attempts.
- Select “Yes” to schedule your broadcast.
- Specify the retry settings if needed.
Finally, click on “Create Broadcast” to finalize the setup. Once the broadcast is sent, you can track its stats, including sent, delivered, and failed messages, directly in Pabbly Chatflow.
Using Pabbly Chatflow for bulk WhatsApp messaging streamlines communication for businesses. By following the detailed steps outlined above, you can effectively manage your messaging campaigns with ease. Automate your outreach today for better engagement!
