1. Accessing Pabbly Connect for WhatsApp Messaging
To start using Pabbly Connect for bulk WhatsApp messaging, visit Pabbly Connect at pabbly.com/chatflow. This platform allows recruitment agencies to send messages efficiently.
If you’re new, click on ‘Sign Up Free’ to create an account. Existing users can log in directly. Once logged in, navigate to the ‘All Pabbly Apps’ section and select Pabbly Chat Flow to get started.
2. Setting Up Pabbly Chat Flow
Once you access Pabbly Chat Flow, you can set up your WhatsApp number. It’s crucial for sending messages through the platform. Ensure your WhatsApp number is linked correctly.
After linking your number, you can create message templates. Templates must be approved by Meta for use. Here’s how to create a template:
- Go to the Templates section in Pabbly Chat Flow.
- Click on ‘Add Template’ and fill in the necessary details.
- Submit for approval and wait for confirmation.
Once approved, your template will be ready for use in bulk messaging.
3. Broadcasting Messages Using Pabbly Connect
To send bulk messages, utilize the broadcasting feature of Pabbly Connect. Navigate to the Broadcast section and click on ‘Start Broadcast’. Here, you can select the type of broadcast campaign.
Set the name of your broadcast, for example, “New Job Opportunity”. Choose your audience by either selecting an existing contact list or uploading a CSV file. If using a CSV, ensure it contains the correct contact information.
4. Optimizing Your Audience for Effective Messaging
In this step, Pabbly Connect allows you to refine your audience. You can exclude certain contacts from receiving messages based on criteria such as recent conversations or specific lists.
Here are the options available:
- Exclude contacts with active chats in the last 24 hours.
- Remove entire contact lists if necessary.
This feature ensures that your messages reach the right people, maximizing engagement.
5. Finalizing Your Broadcast in Pabbly Connect
After setting your audience, you will select the type of message to send. You can choose between a regular message or use a previously approved template. Testing your message is crucial before the final send-off.
Once satisfied, you can schedule your broadcast. Select a future date and time to send your messages or choose to send them immediately. Pabbly Connect also offers automatic retry for failed contacts, ensuring your messages are delivered efficiently.
This tutorial demonstrated how to use Pabbly Connect for bulk WhatsApp messaging in recruitment agencies. By following these steps, you can streamline your communication process and enhance engagement with candidates.
