1. Accessing Pabbly Chatflow for Bulk WhatsApp Messaging
To start sending bulk WhatsApp messages for your furniture business, you first need to access Pabbly Chatflow. Open your web browser and navigate to pabbly.com/chatflow. This will take you to the Pabbly Chatflow homepage.
If you’re a new user, click on the “Sign Up Free” button to create an account. Existing users can simply log in. Once logged in, locate the “All Pabbly Applications” window to find Pabbly Chatflow and click on “Access Now” to enter the dashboard.
2. Setting Up Your Message Template in Pabbly Chatflow
After accessing Pabbly Chatflow, the next step is to create a message template for your bulk WhatsApp messages. This template serves as the foundation for your communications with clients.
- Navigate to the template section in the Pabbly Chatflow dashboard.
- Create a new template and make sure it is approved by Meta.
- Once approved, this template can be used for sending messages.
Ensure your template is clear and concise to effectively communicate your furniture offers. You can customize it further by adding variables to personalize messages.
3. Creating a Broadcast in Pabbly Chatflow
Now, let’s proceed to create a broadcast using Pabbly Chatflow. Go to the broadcast section, where you’ll see options for total broadcasts and messages sent.
Click on the “Add Broadcast” button to initiate the process. Choose the type as “Broadcast Campaign” and name it “Furniture Offer”. In the audience section, you can either select existing contacts or upload a CSV file containing your client data.
4. Importing Contacts via CSV or Existing Lists in Pabbly Chatflow
When creating a broadcast in Pabbly Chatflow, you have the option to import contacts. If you have your client data in Google Sheets, download it as a CSV file first.
- Choose the option to upload a CSV file or select existing contacts.
- Click the “Import” button to create a separate contact list in Pabbly Chatflow.
- Optionally, filter out contacts you do not wish to message.
This allows you to ensure that your messages reach the right audience effectively. Once your contacts are in place, you can proceed to the next steps of the broadcast setup.
5. Testing and Scheduling Your Broadcast in Pabbly Chatflow
Before sending out your bulk messages, it’s essential to test your broadcast using Pabbly Chatflow. You can send a test message to your WhatsApp number to ensure everything is working correctly.
After testing, choose whether to send the broadcast immediately or schedule it for later. If scheduling, select a future date and time to send your messages. Make sure to activate the automatic retry feature for failed messages to enhance delivery rates.
Using Pabbly Chatflow for bulk WhatsApp messaging allows furniture businesses to efficiently reach out to clients. By following these steps, you can streamline your communication and ensure that your offers are effectively delivered.
