1. Introduction to Bulk WhatsApp Messages
Bulk WhatsApp Messages are essential for businesses looking to engage with their customers daily. Using Pabbly Connect, you can automate this process efficiently. This tutorial will guide you through integrating RITYT with Pabbly Connect to send messages to over 100 customers daily.
To start, ensure you have accounts set up for both Pabbly Connect and RITYT. This integration allows seamless communication with your audience, enhancing your marketing efforts.
2. Setting Up Your Pabbly Connect Account
To send Bulk WhatsApp Messages, begin by logging into your Pabbly Connect account. If you don’t have an account, sign up for a free trial. Once logged in, navigate to the dashboard to set up your integration.
  • Click on “Add New Connection” to start the setup.
  • Select “RITYT” as your application for integration.
  • Follow the prompts to connect your RITYT account with Pabbly Connect.
After connecting, you will be able to configure the necessary settings for sending messages. Make sure to verify the connection to avoid any issues later.
3. Creating Your Broadcast Campaign
Now that you have set up your account, it’s time to create a broadcast campaign for your Bulk WhatsApp Messages. In Pabbly Connect, navigate to the “Broadcast” section and click on “Add Broadcast Campaign”.
You’ll need to provide details about your campaign:
  • Enter a name for your broadcast campaign.
  • Select your audience from existing contacts or upload a CSV file.
  • Choose the message type: pre-approved template or regular message.
Once these details are filled out, you can proceed to customize your message content, ensuring it aligns with your marketing goals.
4. Sending Your Bulk WhatsApp Messages
After creating your broadcast campaign, it’s time to send your Bulk WhatsApp Messages. You have two options: send immediately or schedule for later. To send immediately, click on “Send Instantly”.
Alternatively, if you want to schedule your messages:
  • Select “Schedule for Later” and choose the date and time.
  • Ensure you set the retry options for any failed contacts.
Once you confirm your settings, click on “Create Broadcast” to finalize your campaign. Your messages will be sent according to your specified schedule.
5. Monitoring Your Campaign Performance
After your Bulk WhatsApp Messages are sent, monitoring the campaign performance is crucial. In Pabbly Connect, you can track delivery statuses such as sent, delivered, and read rates.
This information helps you understand audience engagement and refine future campaigns. You can analyze:
  • How many messages were delivered successfully.
  • The number of messages read by customers.
  • Any messages that failed to deliver and require re-sending.
This data is invaluable for improving your future Bulk WhatsApp Messages and ensuring better customer engagement.
In this tutorial, we explored how to send Bulk WhatsApp Messages using Pabbly Connect and RITYT. With these tools, you can effectively reach over 100 customers daily and enhance your marketing strategy.
