1. Accessing Pabbly Chatflow for WhatsApp Messaging
To start sending bulk WhatsApp messages, first, access Pabbly Chatflow by visiting pabbly.com/chartflow in your browser. This platform is powered by the official WhatsApp Business Cloud API, which minimizes the risk of your number getting blocked.
Once on the landing page, click on the “Sign Up for Free” button to activate your free trial. This allows you to send up to 100 WhatsApp messages at no cost. After signing up, log into Pabbly Chatflow and ensure you add your WhatsApp number in the dashboard.
2. Adding Your WhatsApp Number in Pabbly Chatflow
To effectively use Pabbly Chatflow, you need to add your WhatsApp number. Click on the “Add WhatsApp Number” button. This will guide you through the necessary steps to integrate your number.
For detailed instructions, refer to the video tutorial linked in the description. Once your number is added, navigate to the “Broadcast” section on the left side of the dashboard to proceed with your messaging campaign.
3. Creating a Broadcast Campaign in Pabbly Chatflow
In this section, you will create a broadcast campaign using Pabbly Chatflow. Start by clicking the “Add Broadcast” button. Choose the broadcast type, which should be set to “Broadcast Campaign” for this purpose.
Next, name your broadcast. For example, if you’re promoting your gym, you could name it “Fitness Zone Offers.” After naming, select your audience. You can upload a CSV file containing comma-separated values or choose from existing contact lists.
  • Upload a CSV file of contacts.
  • Select existing contact lists directly.
Additionally, you can refine the audience by excluding specific contacts or lists. This allows you to tailor your message delivery effectively.
4. Selecting Message Type in Pabbly Chatflow
After setting up your audience, the next step in Pabbly Chatflow is to select the message type. You have two options: a regular message or a pre-approved template message. If you choose the template message, ensure you create the template in the “Template” section beforehand.
For a regular message, simply enter your message content. You can format text using asterisks for bolding. Additionally, you can attach multimedia files such as images, videos, or audio. To verify your message, send a test broadcast to yourself before the actual send-out.
  • Enter your message and format as needed.
  • Attach any multimedia files if required.
Once satisfied, you can either send the message instantly or schedule it for a later time.
5. Monitoring Broadcast Results in Pabbly Chatflow
After your broadcast is sent using Pabbly Chatflow, you can monitor its performance. The platform allows you to view statistics such as sent, delivered, read, pending, ignored, and failed messages.
This feature is crucial for understanding the effectiveness of your campaigns. You can also set up automatic retries for failed contacts, ensuring that your messages reach as many people as possible.
  • View detailed stats for each broadcast.
  • Set retry options for failed messages.
Once you have analyzed the results, you can refine your approach for future broadcasts using Pabbly Chatflow.
In this tutorial, you learned how to use Pabbly Chatflow to send bulk WhatsApp messages effectively. From setting up your account to monitoring results, every step is designed to help you maximize your outreach.
Utilizing Pabbly Chatflow not only streamlines the process but also ensures compliance with WhatsApp guidelines, making your marketing efforts more efficient.
