1. Setting Up Pabbly Connect for WhatsApp Marketing
To begin your Bulk WhatsApp Marketing, access Pabbly Connect through pabbly.com/chatflow. This platform is essential for integrating various applications effectively.
After visiting the website, new users can click on “Sign Up Free” to create an account. Existing users should log in to access their dashboard, where they can find all Pabbly applications, including Pabbly Chatbot.
2. Integrating Pabbly Chatbot with WhatsApp
Once logged into Pabbly Connect, navigate to Pabbly Chatbot. Here, you can link your WhatsApp number to your Chatbot account, which is crucial for sending messages.
To set this up, follow these steps:
- Click on “Access Now” for Pabbly Chatbot.
- Follow the instructions to connect your WhatsApp number.
Once the connection is established, you can start utilizing the broadcast feature for your marketing campaigns.
3. Creating a WhatsApp Broadcast Campaign
To send promotional messages, you must create a broadcast campaign using Pabbly Connect. Start by selecting the broadcast option in the Chatbot dashboard.
Follow these steps to set up your campaign:
- Click on “Add Broadcast” to create a new campaign.
- Name your campaign, e.g., “New Hotel Promotion”.
- Select your audience from existing contact lists or upload a CSV file.
After selecting your audience, you can customize the message type to either a pre-approved template or a regular message.
4. Testing and Scheduling Your Messages
Testing your message is crucial before sending it out through Pabbly Connect. You can send a test message to your WhatsApp number to ensure everything is set up correctly.
To test and schedule your message, follow these steps:
- Enter your WhatsApp number and click “Send Test Message”.
- Once confirmed, you can choose to send the message immediately or schedule it for later.
Ensure you select a future date and time if scheduling, as sending messages immediately will deliver them to all contacts right away.
5. Monitoring Broadcast Results with Pabbly Connect
After sending your broadcast, Pabbly Connect allows you to monitor its performance. You can view delivery statistics, read receipts, and any failed attempts.
To access these statistics:
- Navigate to the broadcast section in your dashboard.
- Review metrics such as delivery, read, and pending statuses.
This data helps you refine future campaigns and improve engagement rates.
In this tutorial, we explored how to leverage Pabbly Connect for effective Bulk WhatsApp Marketing tailored for hotels and resorts. By integrating Pabbly Chat Flow and Chatbot, you can streamline your marketing efforts and enhance guest engagement.
Utilizing these steps, you can successfully create, test, and monitor your WhatsApp broadcasts, ensuring your promotional messages reach your audience effectively.
