1. Accessing Pabbly Connect for Bulk WhatsApp Automation
To start your journey with bulk WhatsApp automation, the first step is to access Pabbly Connect. Open a new tab and search for pabbly.com/chatflow. This will take you to the Pabbly Chatflow landing page, where you can sign up.
Once you’re on the page, click on the ‘Sign Up for Free’ option at the top right corner. After entering your basic details, you’ll gain access to Pabbly Chatflow’s dashboard, which is crucial for managing your WhatsApp messages.
2. Adding Your WhatsApp Number in Pabbly Connect
After accessing Pabbly Connect, adding your WhatsApp number is essential for sending messages. Click on the ‘Add WhatsApp Number’ button to input your number. This step is vital for ensuring that your messages reach the intended audience.
  • Enter your WhatsApp number accurately.
  • Verify the number if prompted.
Once your number is added, navigate to the left sidebar and click on the ‘Broadcast’ section. Here, you will see the option to ‘Add Broadcast’, which allows you to create a new broadcast list for your messages.
3. Creating a Broadcast in Pabbly Connect
In this section, you will learn how to create a broadcast using Pabbly Connect. Click on ‘Add Broadcast’ and choose a name for your broadcast, such as ‘Festive Offer’. This name will help you identify the broadcast later.
  • Select the type of audience for your broadcast.
  • You can either upload a CSV file or choose an existing contact list.
For CSV uploads, provide the file URL or upload it directly. Ensure that your contacts are organized for effective messaging. After this, refine your audience by excluding any contacts you do not wish to message.
4. Sending Messages via Pabbly Connect
Now, it’s time to send your messages using Pabbly Connect. You can choose between sending a test message or broadcasting to your entire audience. To send a test message, fill in the contact name and mobile number, then click on ‘Send Test Message’. This is a crucial step to ensure everything is set up correctly.
Once you confirm that the test message is received correctly on your WhatsApp, you can proceed to send the actual broadcast. You have two options: send immediately or schedule for later. If you choose to send immediately, click on ‘Create Broadcast’.
5. Tracking Your Broadcasts with Pabbly Connect
Finally, tracking the performance of your broadcasts is vital. With Pabbly Connect, you can view statistics such as how many messages were sent, delivered, read, or ignored. This data is crucial for understanding the effectiveness of your campaigns.
To check these stats, navigate to the ‘View Stats’ section after your broadcast is sent. Here, you will find detailed insights that can help you optimize future broadcasts and improve your messaging strategy.
In conclusion, using Pabbly Connect for bulk WhatsApp automation allows you to save time while efficiently reaching your audience. By following these steps, you can ensure that your messages are sent without any hassle, following the best practices for compliance.
