1. Setting Up Pabbly Connect for SMS Automation
To start automating SMS sending, you need to access Pabbly Connect. Head over to pabbly.com/connect and log in or sign up for a free account. This will give you access to 100 free tasks monthly, allowing you to test the integration.
Once logged in, you can create a new workflow. This is where the integration process begins. You will be able to connect Twilio and Google Sheets through Pabbly Connect, ensuring that your SMS messages are sent automatically to your contacts.
The first step in this integration is to connect Google Sheets to Pabbly Connect. You will need to set up a trigger that captures new entries in your Google Sheets. For this, select the “Google Sheets new updated spreadsheet row” option as your trigger event.
To set this up, follow these steps:
  • Open your Google Sheets and go to Extensions > Add-ons > Get add-ons.
  • Search for “Pabbly Connect Webhooks” and install it.
  • Return to your sheet and refresh it to see the Pabbly Connect option.
  • Select “Initial Setup” and paste the Webhook URL provided by Pabbly Connect.
Once the setup is complete, ensure the “Send on event” option is enabled. This will allow new entries to trigger the SMS sending process automatically through Pabbly Connect.
3. Testing the Google Sheets and Pabbly Connect Integration
After setting up the trigger in Google Sheets, it’s essential to test the integration to ensure everything is functioning correctly. To do this, you will need to send a test response from Google Sheets to Pabbly Connect.
Follow these steps for testing:
  • Go back to the Initial Setup in your Google Sheets add-on.
  • Click the “Send Test” button to send the first contact’s details to Pabbly Connect.
  • Check if the details appear in your Pabbly Connect workflow.
This test will confirm that your Google Sheets is properly integrated with Pabbly Connect, allowing for seamless data transfer.
4. Integrating Twilio with Pabbly Connect
Next, you will set up Twilio to send SMS messages through Pabbly Connect. This requires creating a new connection in your workflow. Select the Twilio app and set up the action event for sending SMS.
Here are the steps to connect Twilio:
  • Enter your Twilio Account SID and Auth Token, which you can find in your Twilio dashboard.
  • Compose your SMS message, including any dynamic fields from your previous steps.
  • Map the recipient’s phone number from the Google Sheets response.
After setting up the message, save and test the connection. This will enable you to send SMS messages to your contacts automatically using Pabbly Connect and Twilio.
5. Sending SMS to All Contacts via Pabbly Connect
With both Google Sheets and Twilio integrated through Pabbly Connect, you can now send SMS messages to all your contacts efficiently. Go back to your Google Sheets and use the Pabbly Connect add-on to send all data.
To send messages to multiple contacts, simply select the option to “Send All Data” from the Pabbly Connect menu. This will trigger the workflow you created, sending SMS messages to each contact listed in your Google Sheets.
This method allows you to:
  • Reach thousands of customers quickly.
  • Ensure no contacts are missed.
  • Automate your marketing efforts efficiently.
By using Pabbly Connect, you can streamline your SMS marketing process and enhance your communication strategy with ease.
In summary, using Pabbly Connect to integrate Twilio with Google Sheets allows for automated SMS sending to your contacts. This setup saves time and ensures effective communication without manual effort. Automate your messaging today!
