1. Accessing Pabbly Connect to Create Your WhatsApp AI Assistant
To create a WhatsApp AI assistant, start by accessing Pabbly Connect. Open your web browser and navigate to pabbly.com/chatflow. This will take you to the Pabbly Chatflow homepage where you can initiate the setup.
If you are a new user, click on “Sign up for free” to create an account. Existing users can simply log in. Once logged in, you will be directed to the Pabbly Chatflow dashboard where you can manage your WhatsApp integration.
2. Setting Up Your WhatsApp Number in Pabbly Connect
After accessing Pabbly Connect, the next step is to connect your WhatsApp number. In the dashboard, look for the option to access your WhatsApp settings. This is crucial for enabling the AI assistant to respond to customer queries.
- Click on “Access Now” to enter the Pabbly Chatflow interface.
- Follow the prompts to connect your WhatsApp number.
- Ensure your WhatsApp account is verified for integration.
Once your WhatsApp number is connected, you can proceed to create the AI assistant. This integration allows your assistant to handle customer inquiries seamlessly.
3. Creating Your WhatsApp AI Assistant in Pabbly Connect
To create your WhatsApp AI assistant, navigate to the AI assistant feature within Pabbly Connect. Click on the “Add Assistant” button, and you will be prompted to name your assistant. Choose a relevant name that reflects its purpose.
After naming your assistant, select the instruction type from the dropdown menu. You can choose a custom prompt or predefined options like “AI Agent” or “Customer Support Agent”. For this tutorial, we will use the “AI Agent” option.
- Set the AI configuration parameters, such as temperature and model type.
- Input your OpenAI API key to enable AI functionalities.
- Customize the assistant settings, including header and footer messages.
This setup allows your AI assistant to respond accurately to customer queries on WhatsApp, enhancing your business’s customer service capabilities.
4. Configuring AI Assistant Settings in Pabbly Connect
Once your AI assistant is created, you will need to configure its settings in Pabbly Connect. This includes defining stop keywords, retry attempts, and fallback messages. Stop keywords allow the assistant to cease responses when a user types specific words.
For example, you might choose “human” as a stop keyword, meaning that if a customer types this, the assistant will stop responding, and a human will take over. Additionally, set the number of retry attempts if the assistant fails to respond correctly.
- Define the fallback message for instances when the API fails.
- Upload a knowledge source document to improve response accuracy.
- Customize the assistant interface with your branding elements.
These configurations ensure that your WhatsApp AI assistant is robust and capable of handling various customer interactions effectively.
5. Activating and Assigning Your AI Assistant in Pabbly Connect
After configuring your AI assistant, the final step is to activate it in Pabbly Connect. Enable the assistant by clicking the activation button and save your settings. This will make your assistant live and ready to respond to customer inquiries.
You can assign your assistant to specific WhatsApp chats by navigating to the inbox settings. Here, you can enable auto-reply settings and select the assistant you wish to assign. This allows for bulk assignments across your contact list.
- Select the contact list from the dropdown menu.
- Click on the save button to apply changes.
- For individual chats, access the inbox section and assign the assistant manually.
This process ensures that your WhatsApp AI assistant is effectively integrated and operational, providing your customers with timely responses.
In this guide, we’ve explored how to use Pabbly Connect to create a WhatsApp AI assistant step by step. By following these detailed instructions, you can enhance customer interactions and streamline your business operations.
