To start integrating Pabbly, WhatsApp, and Google Sheets, you first need to access Pabbly Connect. Simply go to pabbly.com/connect. If you are a new user, sign up for free to receive 100 free tasks each month.
Once logged in, you can create your automation setup. This process allows you to manage leads effectively as soon as they come in through your Meta campaigns. You will see how Pabbly Connect enables seamless integration between all the applications involved.
2. Setting Up Facebook Lead Ads in Pabbly Connect
The next step is to set up Facebook Lead Ads as a trigger in Pabbly Connect. This is crucial for capturing leads generated through your Meta campaigns. Choose “Facebook Lead Ads” as your trigger event.
- Select “New Lead” as the trigger event.
- Connect your Facebook account by clicking on the “Add New Connection” button.
- Choose the Facebook page and lead generation form you are using.
Once connected, click on “Save and Send Test Request” to ensure the connection works. Pabbly Connect will wait for a webhook response from your Facebook Lead Ads to confirm the setup.
3. Capturing Lead Data in Google Sheets
After setting up the trigger, it’s essential to capture lead data in Google Sheets using Pabbly Connect. This step ensures that all lead information is systematically recorded.
Select “Google Sheets” as your action event and choose “Add New Row”. Connect your Google account and select the spreadsheet where you want to store the lead data. Make sure to map the fields accurately:
- Map the lead’s name, email, and phone number from the previous step.
- Click on “Save and Send Test Request” to verify the data is recorded correctly.
By doing this, Pabbly Connect automates the process of entering lead data into Google Sheets, ensuring no leads are missed or incorrectly recorded.
4. Sending WhatsApp Messages Using Pabbly Chat Flow
Once the lead data is captured, the next step is to send an automated WhatsApp message using Pabbly Chat Flow. This is crucial for timely follow-ups with leads.
In Pabbly Connect, select “Pabbly Chat Flow” as the action step and choose “Send Text Message”. Connect your Pabbly Chat Flow account by entering the API token from your account settings. Map the WhatsApp number and personalize the message using the lead’s name.
- Enter the message you want to send to the lead.
- Click on “Save and Send Test Request” to send the message.
This integration through Pabbly Connect ensures that leads receive immediate communication, enhancing your engagement strategy.
5. Conclusion: Automating Lead Management with Pabbly Connect
By following these steps, you can effectively manage your leads using Pabbly Connect. This integration allows you to capture leads from Facebook, record them in Google Sheets, and send automated WhatsApp messages.
This process not only saves time but also ensures you never miss a lead. Start using Pabbly Connect today to streamline your lead management system!
