1. Accessing Pabbly Connect for WhatsApp Marketing
To start your WhatsApp marketing campaign, the first step is to access Pabbly Connect. This platform allows you to integrate various applications seamlessly, making it easier to manage your marketing efforts. If you are new, visit Pabbly’s official website to create your account.
After signing up, you will be welcomed with a dashboard. Here, you can find multiple Pabbly applications, including Pabbly Chatflow. This is where you’ll create your WhatsApp marketing campaigns.
2. Setting Up Your WhatsApp Number in Pabbly Connect
The next crucial step involves adding your WhatsApp number to Pabbly Connect. This integration is essential for sending messages to your customers. Navigate to the left sidebar and find the WhatsApp settings.
  • Select the WhatsApp option from the menu.
  • Click on the ‘Add WhatsApp Number’ button.
  • Follow the prompts to verify your number.
Once your number is verified, you can proceed to create broadcast campaigns. This setup is vital for ensuring that your messages reach your audience effectively.
3. Creating Your First WhatsApp Broadcast Campaign
To create a broadcast campaign, go to the Pabbly Chatflow dashboard and select the broadcast feature. This feature allows you to send messages to multiple contacts at once, saving you time and effort.
Click on the ‘Add Broadcast’ button to start. You will be prompted to fill in details such as the name of the broadcast and the contact list you want to use. Ensure you select the correct list to target your audience effectively.
  • Choose a broadcast type (e.g., discount alert).
  • Select the contact list for your broadcast.
  • Optionally refine your audience by excluding certain contacts.
After setting up the broadcast, you can preview how your message will appear to recipients. This step is crucial for ensuring your content is engaging and professional.
4. Scheduling and Sending Your Campaign with Pabbly Connect
Once your broadcast is ready, you can schedule it using Pabbly Connect. This feature allows you to select a specific date and time for your messages to be sent, ensuring they reach your audience at the right moment.
To schedule your broadcast, select the date and time from the scheduling options. You can also enable automatic retries for failed messages to ensure maximum delivery rates.
  • Choose the date and time for sending the broadcast.
  • Enable retries for failed messages.
  • Click on the ‘Schedule Broadcast’ button to finalize.
After scheduling, your campaign will be ready to go, allowing you to focus on other aspects of your business while Pabbly Connect handles your messaging needs.
5. Testing Your WhatsApp Broadcast Campaign
Before launching your campaign, it’s essential to test it using Pabbly Connect. This ensures that everything works as intended and that your messages are delivered correctly.
To test, enter a test contact name and number, then click on the ‘Send Test Message’ button. Check your WhatsApp to confirm that the message appears as expected.
  • Enter a test contact name and number.
  • Click ‘Send Test Message’.
  • Verify the message in your WhatsApp.
Once confirmed, you can confidently proceed with your scheduled broadcast, knowing that your WhatsApp marketing campaign is set up correctly with Pabbly Connect.
Creating a WhatsApp marketing campaign using Pabbly Connect is a straightforward process that allows you to engage with customers effectively. By following the steps outlined above, you can set up, schedule, and test your campaigns seamlessly. Enjoy leveraging the power of WhatsApp marketing!
