1. Accessing Pabbly Connect for Your WhatsApp AI Assistant
To build your first WhatsApp AI Assistant, you need to access Pabbly Connect. Start by opening your browser and navigating to Pabbly’s official website.
Once there, sign up for an account if you haven’t already. After logging in, you’ll find the Pabbly Connect dashboard, which is the central hub for creating your integrations. Here, you can easily manage your WhatsApp AI Assistant setup.
2. Setting Up WhatsApp Integration Using Pabbly Connect
In this step, you will integrate WhatsApp with the AI Assistant using Pabbly Connect. First, select the option to add your WhatsApp number in the dashboard. Ensure you follow the prompts to verify your number.
  • Select ‘Add WhatsApp Number’.
  • Follow the verification steps provided.
  • Confirm your integration settings.
After successfully adding your WhatsApp number, you will be ready to configure your AI Assistant. This integration allows your assistant to respond automatically to customer queries.
3. Creating Your AI Assistant in Pabbly Connect
Now, navigate to the AI Assistant section within Pabbly Connect. Here, you can create a new AI Assistant by selecting the appropriate options. Choose the AI agent type and customize it according to your business needs.
In this section, you will also set the temperature for your AI responses. A temperature of 0.5 is recommended for balanced creativity and focus. Then, select OpenAI as your AI provider.
  • Set the temperature to 0.5.
  • Choose OpenAI as the provider.
  • Select the appropriate AI model, such as GPT-5.4.
After setting these parameters, you will be prompted to enter your API Key. This key enables the connection between your AI Assistant and OpenAI through Pabbly Connect.
4. Configuring AI Assistant Settings in Pabbly Connect
With your AI Assistant created, it’s time to configure its settings within Pabbly Connect. You can customize the header and footer messages that will be displayed during interactions.
Additionally, enable options for stop keywords and retry attempts to enhance the assistant’s functionality. Configure fallback messages to ensure users receive responses even when the AI fails to provide an answer.
  • Customize header and footer messages.
  • Set stop keywords to manage conversations.
  • Enable retry attempts for better user experience.
Once configured, your AI Assistant will be fully equipped to handle customer inquiries effectively through WhatsApp, thanks to the capabilities of Pabbly Connect.
5. Testing Your WhatsApp AI Assistant
After setting everything up, it’s crucial to test your AI Assistant to ensure it functions as expected. Send a message to your WhatsApp number and observe the responses generated by your AI Assistant.
Try various questions to see how well the assistant utilizes your business knowledge base. This testing phase is essential to refine any settings within Pabbly Connect for optimal performance.
  • Send a test message like ‘I need help’.
  • Check the accuracy of responses based on your knowledge base.
  • Adjust settings in Pabbly Connect as needed.
Once you are satisfied with the performance, your WhatsApp AI Assistant will be ready to assist customers 24/7, leveraging the power of Pabbly Connect.
In this tutorial, we demonstrated how to build your first WhatsApp AI Assistant using Pabbly Connect. With the right setup, you can automate customer responses efficiently.
