To create an AI chatbot for WhatsApp, start by accessing Pabbly Connect. This platform will help you integrate Pabbly, Pabbly Chat Flow, and OpenAI seamlessly. Once logged in, navigate to the Pabbly Connect dashboard.
Here, you will find options to set up integrations. Click on the “Create Workflow” button to initiate the process. This step is crucial as it lays the foundation for connecting your applications using Pabbly Connect.
2. Creating Your AI Agent in Pabbly Chat Bot
Next, you will create an AI agent using the Pabbly Chat Bot feature. Click on the “Add AI Assistant” button to get started. You will need to name your assistant, for example, “AI Agent”.
  • Choose the instruction type as “AI Agent”.
  • Set the temperature to control response creativity.
  • Select OpenAI as your AI service provider.
After configuring these settings, proceed to enter your OpenAI API key. This key is essential for allowing your AI agent to communicate with OpenAI through Pabbly Connect.
3. Configuring AI Agent Settings
Once your AI agent is created, navigate to the settings section to customize its behavior. Here, you can add a welcome message and set up keywords for stopping the conversation.
  • Add a header or footer message if needed.
  • Define keywords that will trigger the AI to stop responding.
  • Customize retry attempts for the AI agent.
These configurations ensure that your AI agent behaves as intended. Finally, save your settings to complete this step in Pabbly Connect.
4. Setting Up Your Knowledge Base
The knowledge base is crucial for your AI agent’s performance. You can upload a PDF or text file containing information relevant to your business. This file will serve as the source of knowledge for your AI agent.
To upload your knowledge base, click on the “Add New File” option and select the appropriate document. Ensure that your file complies with the accepted formats (.txt or .pdf) and size limitations.
5. Finalizing Your AI Agent
After uploading the knowledge base, return to the main settings of your AI agent. Here, you can modify the appearance and finalize the activation of your AI agent.
Once you are satisfied with all configurations, click on the “Save AI Assistant” button. This action activates your AI agent, making it ready for interaction on WhatsApp through Pabbly Connect.
In this tutorial, we explored how to integrate Pabbly, Pabbly Chat Flow, and OpenAI using Pabbly Connect. By following these steps, you can build an AI chatbot for WhatsApp that responds intelligently to customer inquiries.
