To start building your first automation with Pabbly Connect, open your browser and navigate to pabbly.com/connect. This is the first step to accessing the powerful integration platform.
Once on the landing page, click on the “Sign Up for Free” option in the top right corner. This will allow you to create a free trial account for Pabbly Connect. After signing up, you can explore its features and decide if you want to continue with a paid subscription later.
2. Creating Your First Workflow in Pabbly Connect
With Pabbly Connect ready, log into your account and navigate to the dashboard. Click on the “Create Workflow” button to start setting up your automation.
For this example, we will create a workflow that collects leads and saves them in Google Sheets. Here’s how to set it up:
  • Select the trigger application, which is Typeform in this case.
  • Choose the event “New Entries” to trigger the workflow.
  • Set up actions to save lead details in Google Sheets.
After selecting the trigger, Pabbly Connect will guide you through the process of setting up each action needed for your workflow.
3. Integrating Applications with Pabbly Connect
Now that you have your trigger set, it’s time to integrate other applications using Pabbly Connect. You can add various actions such as sending WhatsApp messages, creating contacts in Zoho CRM, and notifying your sales team on Slack.
Follow these steps to complete the integration:
  • Select the WhatsApp Cloud API to send messages.
  • Choose “Create Contact” for Zoho CRM as your next action.
  • Set up a notification to your sales team via Slack.
Each action will be suggested by Pabbly Connect, making it easy to create a comprehensive automation workflow.
4. Finalizing Your Automation
After setting up all the actions, you can review the entire workflow in Pabbly Connect. This platform allows you to see each step clearly, ensuring everything is in place.
Once you are satisfied with your setup, click on the “Approve and Create” button. This will finalize your automation, and you’ll see a confirmation that your workflow has been created successfully.
With Pabbly Connect, you can create complex automations quickly, often under five minutes. This efficiency is a game-changer for businesses looking to streamline their processes.
5. Testing Your Automation in Pabbly Connect
Once your workflow is created, it’s essential to test it to ensure everything functions as expected. Use Pabbly Connect to run a test by submitting a sample entry through Typeform.
Monitor the results in each connected application to verify that data is being captured correctly. This includes checking Google Sheets, Zoho CRM, and any notifications sent through Slack or WhatsApp.
If everything works as intended, your automation is ready to go live! Remember, Pabbly Connect simplifies the process of integrating multiple applications, making it accessible for everyone.
In conclusion, using Pabbly Connect allows you to build your first automation effortlessly in just five minutes. By following the steps outlined in this tutorial, you can integrate various applications like Google Sheets, Zoho CRM, and WhatsApp to streamline your workflow.
