To create an automated WhatsApp chatbot, the first step is to access Pabbly Chatflow. You can do this by visiting the official Pabbly Chatflow website. If you are a new user, you will need to sign up for a free account to get started.
Once you are on the homepage, click on the ‘Sign Up Free’ button. New users receive 100 free credits monthly, which is perfect for practicing and exploring the features of Pabbly Chatflow. Existing users can simply log in using the ‘Sign In’ button.
2. Creating Your WhatsApp Chatbot Flow in Pabbly Chatflow
After logging into Pabbly Chatflow, navigate to the flow page, which is essential for building your WhatsApp chatbot. Ensure that you have linked your WhatsApp number to your Pabbly account as this is crucial for the chatbot to function properly.
  • Select the flow page from the sidebar.
  • Create a new flow and name it appropriately.
  • Set a trigger event for your chatbot, such as keyword matching.
For this example, you can set the trigger to respond when a user sends the message “hello”. This will initiate the chatbot’s response flow, allowing users to interact seamlessly via WhatsApp.
3. Building Responses and Actions in Pabbly Chatflow
With your trigger set, the next step is to create the responses your WhatsApp chatbot will provide. Use the message blocks in Pabbly Chatflow to construct your welcome message. For example, you can greet users and provide them with options to explore trending gifts.
  • Drag and drop a text block to enter your welcome message.
  • Add a button labeled “Trending Gifts” for user interaction.
  • Configure the button to act as a quick reply.
When users click on the “Trending Gifts” button, they will receive a list of products categorized for easy selection. This interaction enhances the user experience and streamlines the ordering process through WhatsApp.
4. Finalizing and Testing Your WhatsApp Chatbot
Once you have built the flow and responses, it’s time to finalize your WhatsApp chatbot in Pabbly Chatflow. Ensure all buttons and responses are correctly connected to maintain a smooth user experience.
After setting up the responses, save your flow using the save button. You will receive a confirmation pop-up indicating that your flow has been saved successfully. Testing your chatbot is essential to ensure all functionalities work as intended before going live.
Engage in testing by sending messages to your WhatsApp number to see how the chatbot responds. This will help you identify any necessary adjustments to improve user interaction.
5. Conclusion: Automate Your Business with Pabbly Chatflow
In conclusion, using Pabbly Chatflow to create an automated WhatsApp chatbot can significantly enhance your e-commerce business. By following the steps outlined, you can streamline customer interactions and facilitate order placements directly through WhatsApp.
Not only does this automation save time, but it also provides a seamless experience for your customers. Start using Pabbly Chatflow today to automate your processes and improve customer engagement.
