To start integrating your applications, first access Pabbly Connect by visiting pabi.com. Click on the sign-in button to log into your account.
Once logged in, you will see a dashboard showcasing all Pabbly apps. Select Pabbly Studio and click on “Access Now” to begin your integration journey.
2. Creating Your Mock Test App in Pabbly Studio
After accessing Pabbly Studio, you will be prompted to describe your app in a designated box. For this tutorial, we will create a mock test app named Krux.
In your request, include the following details to ensure a smooth build process:
- A student picks a subject and starts a timed test.
- Each answer is marked immediately upon selection.
- At the end, the score is displayed as a percentage along with weak areas.
Once your request is complete, simply press send. Pabbly Connect will handle the app-building process, ensuring all features are implemented correctly.
3. Understanding the Building Process with Pabbly Connect
The building process begins immediately after your request is sent. Pabbly Connect utilizes its AI capabilities to create the app step-by-step, starting with a plan.
During this phase, you will see a checklist of tasks being completed. The app will include:
- Timed practice tests by subject.
- Instant marking with correct answers.
- A record of weak areas for improvement.
After a few minutes, the build will be completed, and your app will be online with its unique link provided by Pabbly Connect.
4. Testing Your Mock Test App
Once your app is live, you can start testing its functionality. Sign in to view the main screen, which displays your average score, best score, and the time spent on tests.
Begin a timed test in a chosen subject, where each question is displayed one at a time. As you select answers, they will be marked immediately, allowing for instant feedback.
At the end of the test, you will see your total score, the number of correct answers, and the topics you struggled with. This feedback is essential for targeted practice and is facilitated through Pabbly Connect’s integration capabilities.
5. Making Changes with Pabbly Connect
After testing your app, you may want to make adjustments. Using Pabbly Connect, you can easily send a new message to add features like an exam countdown on your dashboard.
Once you send the request, Pabbly Connect will modify only the necessary parts of your app and publish the new version seamlessly. You can even roll back changes if needed, ensuring that all versions are saved for easy access.
With Pabbly Connect, every modification is straightforward, allowing you to keep your app updated without any coding knowledge.
In summary, integrating applications using Pabbly Connect is a seamless process. From creating a mock test app to testing and making changes, Pabbly Connect simplifies every step, ensuring a user-friendly experience.
