1. Setting Up Pabbly Connect for Your Chatbot
To create an appointment booking chatbot, the first step is to access Pabbly Connect. This platform will facilitate the integration between various applications like Pabbly Chatbot, Google Sheets, and more. Start by logging into your Pabbly account and navigating to the Connect dashboard.
Once you are in Pabbly Connect, you can create a new workflow. This workflow will handle the automation of your chatbot’s interactions. Begin by selecting the trigger application, which in this case is Pabbly Chatbot. This allows you to set up the initial event that will kick off your automation process.
2. Designing the Chatbot Flow in Pabbly Chatbot
Next, you need to design the chatbot flow using Pabbly Chatbot. Start by giving your flow a name that reflects its purpose, such as “Appointment Booking Bot”. You will see various buttons on the left side of the screen to help you design your flow.
  • Choose a trigger event, like a keyword that the patient might send.
  • Add a welcome message that greets the patient.
  • Include quick reply buttons for options like “Book Appointment” or “Our Doctors”.
After setting up these elements, connect the nodes in your flow to ensure the chatbot responds appropriately to user inputs. This setup will allow patients to initiate the booking process seamlessly.
3. Collecting Patient Information
Once the patient selects the “Book Appointment” option, your chatbot should prompt them to provide necessary details. Use Pabbly Connect to link their responses to specific fields. For instance, ask for the type of appointment, date, and time.
  • Create a list of appointment types for the patient to choose from.
  • Request the preferred date and time for the appointment.
  • Capture the patient’s name, age, and reason for the visit.
By integrating these fields into your chatbot flow using Pabbly Connect, you can dynamically collect and store patient information, ensuring a smooth booking experience.
4. Storing Data in Google Sheets
After gathering all patient details, the next step is to store this information in Google Sheets. This is where Pabbly Connect plays a crucial role. You will set up an action in your workflow to add a new row in Google Sheets every time an appointment is confirmed.
To do this, go back to your Pabbly Connect dashboard and select Google Sheets as your action application. Choose the event type as “Add New Row” and link it to the specific sheet where you want to store the appointment data. Map the fields you collected from the chatbot to the corresponding columns in your Google Sheet.
This integration ensures that all patient data is automatically recorded in your Google Sheets, making it easy to track appointments and manage patient information efficiently.
5. Finalizing the Chatbot Flow
Finally, you need to finalize your chatbot flow in Pabbly Chatbot. After the patient confirms their appointment, send them a personalized confirmation message that includes all the details they provided. This message can be dynamically generated using the fields captured earlier.
To complete the setup, connect the confirmation message node to the previous nodes in your flow. Ensure that the chatbot can also handle requests for cancellation or changes to appointments. This versatility will enhance user experience and efficiency.
With everything set up, your appointment booking chatbot is now fully functional. By leveraging Pabbly Connect, you have automated the entire process from patient inquiry to data storage in Google Sheets, providing a seamless experience for both patients and your practice.
In this tutorial, we demonstrated how to create a free appointment booking chatbot using Pabbly Connect, integrating Pabbly Chatbot and Google Sheets. This setup automates patient interactions and data management, streamlining your appointment processes effectively.
