To start using Pabbly Connect, log into your Pabbly account and navigate to the Pabbly Connect dashboard. This platform allows you to automate workflows between various applications, including Pabbly, Pabbly Chat Flow, Skill Up, and Pabbly Plus.
Once you’re in the dashboard, you can create a new workflow. Select the applications you want to integrate, and Pabbly Connect will guide you through the setup process. This is essential for ensuring a seamless connection between your chosen applications.
2. Creating a Chat Flow Integration with Pabbly Connect
In this step, we will create a chat flow using Pabbly Chat Flow. Start by selecting the “Create New Flow” option in Pabbly Chat Flow. You will need to name your flow appropriately for easy identification later.
After naming your flow, you will see various buttons on the left side to design your chatbot path. For this integration, you will select the trigger event that starts your chatbot flow. Here’s how to do it:
- Click on the “Trigger Event” option.
- Choose the “Template Selected” trigger.
- Select the training skill registration template.
As you proceed, you will see a message template that includes quick buttons for exploring courses, registering now, and location. This setup is crucial for guiding users through the chatbot experience.
3. Integrating Skill Up AI Assistant into Your Flow
The next step involves integrating the Skill Up AI assistant into your chatbot flow. To do this, click on the “Actions” option and select “Assign AI Assistant.” Choose the Skill Up AI assistant that you have previously created in your Pabbly Chat Flow account.
Now, configure your AI assistant by defining the type of instructions it will follow. This includes setting the temperature, linking your OpenAI account, and uploading your business knowledge base. Here’s what you need to do:
- Select the instruction type for your AI assistant.
- Provide specific instructions to guide the AI.
- Upload your business knowledge base for better responses.
>By following these steps, you’ll ensure that your AI assistant is well-equipped to handle user inquiries effectively.
4. Finalizing Your Chatbot Flow with Pabbly Connect
After setting up your AI assistant, it’s time to finalize your chatbot flow. You will connect various nodes in your flow to ensure a seamless user experience. For instance, when a student clicks on the “Explore Courses” button, the AI assistant will handle the conversation automatically.
To finalize your flow, you need to add a list button that sends a message in a list format. Here’s how to do that:
- Add a list button from the options.
- Enter the message in the main text box.
- Connect the “Explore Now” node to the list node.
>Once you have configured these elements, your chatbot will be ready to interact with users in a structured manner. Make sure to save your flow to ensure all changes are applied.
5. Testing and Launching Your Chatbot with Pabbly Connect
Before launching your chatbot, it’s crucial to test its functionality. Use the Pabbly Connect testing feature to simulate user interactions and ensure that the bot responds as expected. This step is vital for identifying any potential issues.
After successful testing, you can launch your chatbot. To do this, click the “Save” button to update your flow. With everything set up correctly, your chatbot will operate continuously, providing assistance to users even when you are unavailable.
In summary, using Pabbly Connect, you have successfully integrated Pabbly, Pabbly Chat Flow, Skill Up, and Pabbly Plus to create an automated WhatsApp chatbot. This setup allows for efficient user interactions and enhances the overall experience.
This tutorial has guided you through integrating Pabbly, Pabbly Chat Flow, Skill Up, and Pabbly Plus using Pabbly Connect. By following these steps, you can create an efficient automated chatbot for your business needs.
