To start integrating Pabbly with WhatsApp, you first need to access Pabbly Connect. Visit the Pabbly website and log in to your account. If you are a new user, sign up for a free account to explore its features.
Once logged in, navigate to the Pabbly Connect dashboard. Here, you can manage your integrations and see the options available to connect various applications, including WhatsApp. Make sure to have your WhatsApp number ready for the integration.
2. Creating an AI Assistant with Pabbly Connect
Using Pabbly Connect, you can create an AI assistant to respond to inquiries on WhatsApp. Click on the ‘Add AI Assistant’ button on the dashboard to begin. You will be prompted to name your assistant, which will help identify it later.
  • Choose a meaningful name for your assistant.
  • Select AI instructions and set up knowledge sources.
  • Configure the assistant interface and styling options.
After setting up the assistant, click on the ‘Save’ button to finalize the setup. This assistant will now be ready to handle queries automatically on WhatsApp.
Once your AI assistant is created, the next step involves configuring its settings. In Pabbly Connect, navigate to the AI settings section. Here, you will set the temperature for responses, which determines the creativity of the replies.
You can also upload any relevant documents or knowledge sources that the AI can refer to when responding to queries. This ensures that the assistant provides accurate information based on your business needs.
  • Set the temperature to balance focused and creative responses.
  • Upload necessary documents for reference.
  • Add headers and footers for responses.
Make sure to save your settings to ensure that the assistant operates as intended when integrated with WhatsApp.
4. Creating a Flow in Pabbly Connect for WhatsApp
To link your AI assistant with WhatsApp, you need to create a flow in Pabbly Connect. Click on the ‘Flows’ tab and then the ‘Add Flow’ button. This will allow you to create a new flow that triggers the AI assistant whenever a message is received on WhatsApp.
While creating the flow, you will set a trigger based on keywords. For instance, typing ‘Hi’ will activate the assistant. You can add multiple keywords to make the interaction more dynamic and responsive.
  • Name your flow meaningfully for easy identification.
  • Select the appropriate trigger conditions.
  • Assign the AI assistant to the flow.
Once the flow is set up, save it to activate the integration. Your AI assistant will now automatically respond to queries on WhatsApp based on the defined triggers.
5. Testing the Integration of Pabbly with WhatsApp
After setting up the flow, it’s time to test the integration of Pabbly Connect with WhatsApp. Simply send a message to your WhatsApp number and observe how the AI assistant responds. This is crucial to ensure everything is working as expected.
For example, when you send a greeting like ‘Hi’, the AI should reply with a friendly message, asking how it can assist you. Test various scenarios to confirm that the assistant provides accurate and helpful responses based on the configured settings and knowledge sources.
Make sure to refine the AI responses based on the feedback and interactions you receive. This will help improve user experience and ensure that the assistant meets the needs of your users effectively.
By following this tutorial, you can successfully integrate Pabbly with WhatsApp using Pabbly Connect. This automation allows your AI assistant to handle inquiries efficiently, enhancing user engagement and support.
