To start integrating your WhatsApp chatbot, access Pabbly Connect by visiting the official website. Once there, you can sign in or create a new account if you are a new user. This platform is essential for automating interactions between your WhatsApp and your customers.
After logging in, navigate to the dashboard where you can manage your integrations. Here’s how to proceed:
  • Click on “Add WhatsApp Number” to link your WhatsApp to Pabbly Connect.
  • Choose the preferred connection method: “WhatsApp Connect” or manual token entry.
Once your number is connected, you can start setting up your AI assistant. This is a crucial step to ensure your chatbot can respond effectively to customer queries.
2. Creating Your AI Assistant with Pabbly Connect
In this section, you will create your AI assistant using Pabbly Connect. Click on the “Add Assistant” button to start. Name your assistant, for example, “Baby Care and Kids Store Bot.” This name should reflect the purpose of the assistant.
Once named, select the instruction type as “AI Agent”. This is vital as it defines how your assistant will respond to queries. The next steps include:
  • Set the creativity level of responses (between 0 to 1).
  • Choose the AI model, such as Open AI GPT 5 Mini.
  • Input your API key from Open AI to enable communication.
After configuring these settings, click on “Connect” to save your API key. This integration through Pabbly Connect is essential for your AI assistant to function correctly.
Next, you will configure specific settings for your AI assistant using Pabbly Connect. This includes setting up the header and footer messages to personalize your chatbot responses. Toggle these options on and enter your desired messages.
Additionally, you can set a stop keyword that users can send to halt the assistant’s responses. Here are the steps to finalize your settings:
  • Define the retry attempts for unresponsive queries (1 to 10).
  • Add fallback messages for when the AI cannot resolve queries.
  • Upload a knowledge base document to assist the AI in providing accurate responses.
These settings enhance the performance of your WhatsApp AI assistant, making it more effective in responding to customer inquiries through Pabbly Connect.
4. Styling Your AI Assistant Using Pabbly Connect
Once your AI assistant is configured, you can style it to align with your brand using Pabbly Connect. This includes choosing themes, colors, and layout options. You can opt for a light or dark theme based on your preference.
Here are the styling options you can customize:
  • Set the shape of the assistant (circle, square, rounded).
  • Customize the background color, text color, and button color.
  • Upload a profile picture for the assistant.
After completing these styling options, toggle the assistant to active and save your settings. This finalizes the look and functionality of your AI assistant within Pabbly Connect.
5. Assigning Your AI Assistant to Contacts via Pabbly Connect
Finally, assign your AI assistant to specific contacts or groups using Pabbly Connect. Navigate to the contact settings and select the AI assistant you created. This ensures that the assistant can respond to messages from the selected contacts.
To assign the assistant efficiently, follow these steps:
  • Choose the contact list you want to assign the assistant to.
  • Select the AI assistant from the dropdown menu.
  • Save your settings to finalize the assignment.
This step is crucial for ensuring that your WhatsApp AI assistant is ready to handle customer queries effectively through Pabbly Connect.
In this tutorial, we explored how to integrate a WhatsApp chatbot using Pabbly Connect. By following these steps, you can automate customer interactions and enhance engagement through effective communication. Start your journey with Pabbly Connect today!
