1. Accessing Pabbly Connect for Social Media Automation
To start automating your social media posts, you first need to access Pabbly Connect. Open your browser and search for Pabbly.com. Once on the homepage, you will see options to sign in or sign up for a free account.
If you are a new user, click on “Sign Up Free” to get started. Existing users can simply click on “Sign In”. New users can access 100 free tasks every month, making it easy to explore the software.
Once logged in, navigate to the Pabbly Connect dashboard. Here, you will create a new workflow. Click on “Create Workflow” and select the option to create from scratch.
In this section, you will set up the workflow to generate social media content automatically. You will be prompted to define the trigger for your workflow. Choose a schedule to trigger the automation on specific days, like Sundays and Wednesdays.
- Select “Schedule Workflow” as the trigger.
- Choose the days of the week for posting.
- Set the time for automation, e.g., 11:00 AM.
After setting the trigger, save your settings to proceed to the next step of your workflow creation.
3. Generating Content Using Pabbly Connect
Now that your workflow is set up, the next step is to generate content for your social media posts. For this, you will utilize the AI capabilities of Pabbly Connect. In the workflow, add an action step to generate content using Gemini AI.
Choose the option to create and publish content. You will need to provide a prompt that describes the content you want to generate. After entering the prompt, select the model and method for generating the content.
- Select “Gemini 2.5 Flash” from the model dropdown.
- Choose “Generate Content” as the method.
Once you have configured these settings, save the action step to complete the content generation setup.
4. Sharing Posts on Facebook and Instagram
After generating the content, the next step is to share it on your social media accounts. This is where Pabbly Connect truly shines, as it allows you to post seamlessly on both Facebook and Instagram.
Start by adding another action step in your workflow to share the generated content. For Instagram, select the option to create and publish a photo. For Facebook, choose to create a page photo post.
- Map the generated content to the respective fields for Instagram.
- Map the same content for Facebook’s post description.
After mapping the fields, review your workflow settings and click on “Save and Send Request” to share your posts. You will receive a successful response indicating that your posts have been shared.
5. Conclusion
Using Pabbly Connect to automate your social media posting on platforms like Facebook and Instagram is straightforward. By following the steps outlined in this guide, you can efficiently create and share content without manual effort. This automation not only saves time but also ensures consistency in your social media presence.
With the power of Pabbly Connect, you can easily manage your social media marketing and focus on growing your business.
