To begin automating your social media posts, access Pabbly Connect by visiting pabbly.com/connect in your browser. This platform is essential for integrating various applications seamlessly.
If you’re a new user, click on the “Sign Up for Free” option to create an account. Existing users can simply sign in. Once logged in, you will be directed to the Pabbly Connect dashboard, where you can start creating your automation workflows.
After accessing the dashboard of Pabbly Connect, the next step is to create a workflow. Click on the “Create Workflow” button to begin. You can choose to create from scratch or use the quick builder.
  • Select “Create Using AI” for a guided setup.
  • Describe your workflow requirements, including triggering daily posts.
  • Choose the relevant applications for Facebook, Instagram, and LinkedIn.
Once you have set your requirements, approve the workflow to finalize the setup. This process allows Pabbly Connect to manage your social media posts efficiently.
3. Setting Up Triggers in Pabbly Connect
Triggers in Pabbly Connect determine when your automation will run. For this example, select the “Schedule Workflow” option to trigger your workflow daily. Choose the time you want the posts to go live.
After setting the trigger, you will see a confirmation message indicating that your workflow is scheduled successfully. This ensures that your social media posts are generated and posted automatically every day without manual effort.
4. Integrating OpenAI with Pabbly Connect
To generate content for your posts, integrate OpenAI through Pabbly Connect. You will need to obtain an API key from your OpenAI account. Follow the prompts to create a new secret key and copy it into Pabbly Connect.
After connecting OpenAI, specify the AI model you want to use, such as GPT-5. Provide the necessary prompts for generating relevant content for your social media posts. This setup allows Pabbly Connect to create unique posts tailored to your audience.
5. Posting to Social Media Platforms via Pabbly Connect
Once the content is generated, it’s time to share it on your social media accounts. For Instagram, use the shortened URL for the image generated through OpenAI. Ensure that your Instagram account is connected to your Facebook account for seamless posting.
  • Map the caption generated by OpenAI to the Instagram post.
  • Repeat the process for Facebook and LinkedIn, ensuring the URLs are correctly formatted.
After setting up these connections, you will receive a confirmation message indicating that your posts have been successfully shared on each platform. This integration with Pabbly Connect automates your social media presence effectively.
In this tutorial, we explored how to automate social media posts using Pabbly Connect. By integrating OpenAI and scheduling posts to platforms like Facebook, Instagram, and LinkedIn, you can save time and enhance your online presence. Start using Pabbly Connect today for efficient social media management.
