1. Accessing Pabbly Chatflow for Automation
To start automating WhatsApp conversations, you first need to access Pabbly Chatflow. Simply go to your browser and enter Pabbly.com/chatflow to reach the homepage.
Once on the homepage, log in to your existing account or sign up for a free trial if you are new. After logging in, navigate to the Pabbly Chatflow dashboard where you can create your chatbot.
2. Creating Your AI Assistant in Pabbly Chatflow
Creating an AI assistant is crucial for automating your WhatsApp conversations with Pabbly Chatflow. On the left sidebar, select the “AI Assistant” option to begin.
  • Click on “Add AI Assistant” to start the setup.
  • Name your assistant, e.g., “Real Estate Assistant for Prime Nest Realty”.
  • Choose the AI instructions type from the dropdown menu.
After filling in these details, you can customize your assistant’s responses based on your business needs. Make sure to select the appropriate AI provider, such as OpenAI, to enhance your assistant’s capabilities.
3. Configuring AI Settings in Pabbly Chatflow
Configuring the AI settings is essential for your assistant to function effectively. In Pabbly Chatflow, you will need to input various parameters, including the API key from OpenAI.
Ensure you set the following options:
  • Set the AI model to “GPT-4 mini” for optimal performance.
  • Input your OpenAI API key.
  • Configure retry attempts and emergency messages.
These configurations will help your AI assistant respond accurately to user queries, enhancing the overall user experience.
4. Uploading Your Knowledge Base to Pabbly Chatflow
Uploading a knowledge base is a vital step in training your AI assistant. In Pabbly Chatflow, you can upload a file containing all necessary information about your services.
Follow these steps to upload your knowledge base:
  • Select the option to upload a new file.
  • Choose a .txt or .pdf file that contains detailed information about your real estate services.
  • Ensure the file is within the size limits set by Pabbly Chatflow.
Once uploaded, your AI assistant will have access to this information, allowing it to provide accurate responses based on user inquiries.
5. Finalizing and Deploying Your AI Assistant
Once you have configured all settings and uploaded your knowledge base, it’s time to finalize your AI assistant in Pabbly Chatflow. Ensure that all options are activated for your assistant to function properly.
Finally, you can integrate your assistant into your website or WhatsApp by using the provided code snippet. This integration allows for seamless communication with your clients, enhancing your service delivery.
By following these steps, you can effectively automate your WhatsApp conversations using Pabbly Chatflow, creating a powerful AI assistant for your business.
In conclusion, utilizing Pabbly Chatflow to integrate various applications like OpenAI and Prime Nest Realty can significantly enhance your customer interaction and streamline your operations.
