To begin integrating applications, you need to access Pabbly Connect. This platform facilitates seamless connections between various applications, including OpenAI and Google Docs.
Once logged into your Pabbly Connect account, you can navigate to the dashboard where the integration process begins. Here, you will set up workflows that connect your desired applications.
2. Creating an AI Assistant with Pabbly Chatbot
In this section, we will create an AI assistant using Pabbly Chatbot. Start by clicking on the “Add AI Assistant” button. This allows you to configure the assistant for your specific needs.
- Enter a name and description for your AI assistant.
- Choose the type of instructions for the assistant.
- Set the temperature level for creative responses.
After setting these parameters, you can proceed to connect the assistant to OpenAI by entering your API key. This key is crucial for allowing your assistant to interact with OpenAI’s capabilities.
3. Configuring OpenAI Integration in Pabbly Connect
To configure OpenAI integration, you will need to select the appropriate AI provider within Pabbly Connect. Choose OpenAI and specify the version, such as GPT-4o Mini, for your assistant.
Next, input your OpenAI API key, which you can generate from your OpenAI account. This key is essential for authenticating your requests and enabling the assistant to function correctly.
- Navigate to the OpenAI API keys section.
- Click on “Create New Secret Key” to generate your API key.
- Copy the key and paste it into the Pabbly Connect interface.
After entering the API key, click the “Connect” button to establish a secure link between your assistant and OpenAI.
4. Uploading Knowledge Base for Your Assistant
Your AI assistant needs a knowledge base to provide accurate responses. Using Pabbly Connect, you can upload a knowledge base file in PDF or text format.
Ensure your knowledge base contains all relevant information about your services. You can create this file using Google Docs or any text editor. Then, upload it through the provided interface in Pabbly Connect.
- Select the “Add New File” option in the knowledge base section.
- Choose your file and confirm the upload.
- Ensure the file size is under 90 MB for successful upload.
Once uploaded, your AI assistant will utilize this knowledge base to answer customer inquiries effectively.
5. Designing Your AI Assistant Interface
Finally, design the interface of your AI assistant within Pabbly Connect. Customize the appearance by modifying titles, colors, and other visual elements.
Activate your assistant by toggling the switch to make it live. After saving all changes, your assistant will be ready to interact with users on WhatsApp.
- Change the title to reflect your brand, such as “Pixel Craft Digital Agency”.
- Add initial messages to greet users.
- Ensure all settings are configured before going live.
With these steps completed, your AI assistant is now fully functional and can provide immediate responses to customer queries on WhatsApp.
In this tutorial, we demonstrated how to use Pabbly Connect to integrate various applications, creating an AI-powered WhatsApp assistant. By following these steps, you can enhance customer interaction effectively.
