To create an automated WhatsApp assistant, the first step is to access Pabbly Connect. This platform allows seamless integration between WhatsApp and various applications, including AI services.
Start by visiting the Pabbly website and logging into your account. If you are a new user, click on the sign-up option to create an account. Once logged in, navigate to the Pabbly Connect dashboard where you can manage your integrations.
2. Adding Your WhatsApp Number to Pabbly Connect
Next, you need to add your WhatsApp number to the Pabbly Connect account. This is essential for the assistant to respond to queries on WhatsApp.
To do this, follow these steps:
  • Go to the assistant feature in Pabbly Connect.
  • Click on the settings icon to manage your WhatsApp integration.
  • Enter your WhatsApp number and save changes.
After adding your number, ensure that you verify it to enable communication through your assistant. This integration is crucial for the assistant to function properly on WhatsApp.
3. Creating the WhatsApp Assistant in Pabbly Connect
The next step is to create your WhatsApp assistant using Pabbly Connect. This involves setting up the assistant with the required parameters to respond to user queries effectively.
To create an assistant, click on the “Add Assistant” button and provide a descriptive name. For example, you might name it “AI Healthcare Assistant”. This name will help you identify it later.
  • Select the instruction type as “AI Agent”.
  • Set the temperature for responses, which controls creativity. A value of 0.5 is recommended for balanced replies.
  • Choose OpenAI as the model provider and select the GPT model.
These settings will define how your assistant interacts with users and delivers responses based on the queries received.
4. Uploading the Knowledge Base for Your Assistant
To make your assistant effective, you need to upload a knowledge base. This is where Pabbly Connect shines, allowing you to provide specific information that the assistant can use to respond accurately.
Follow these steps to upload your knowledge base:
  • Create a knowledge base file in PDF or text format, ensuring it is under 90 MB.
  • Click on the “Add New File” option in Pabbly Connect.
  • Upload your knowledge base file and click “Insert”.
This knowledge base will allow your assistant to provide tailored responses to healthcare queries, enhancing user experience significantly.
5. Finalizing the Assistant Settings in Pabbly Connect
After setting up your assistant and uploading the knowledge base, the last step is to finalize the settings in Pabbly Connect. This ensures your assistant is ready for use.
Go to the inbox settings and enable the AI auto-reply feature. Make sure to select your assistant from the dropdown menu and save the changes. This will activate the assistant for all your contacts on WhatsApp.
To conclude the setup:
  • Test the assistant by sending queries to ensure it responds accurately.
  • Make adjustments as necessary based on test results.
With these settings finalized, your automated WhatsApp assistant is now fully operational, ready to assist users with healthcare queries efficiently.
In this tutorial, we explored how to create an automated WhatsApp assistant using Pabbly Connect. By following the steps outlined, you can set up a responsive assistant that interacts with users effectively and provides accurate information.
Utilizing Pabbly Connect for this integration enables businesses to automate responses on WhatsApp, enhancing customer engagement and support.
