1. Accessing Pabbly Chatflow to Build Your AI Loan Advisor
To create an AI Loan Advisor for WhatsApp, the first step is accessing Pabbly Chatflow. If you are not an existing user, visit pabblab.com/chartflow to sign up. You will receive 100 free credits monthly to explore the software.
Once you log into Pabbly Chatflow, navigate to the dashboard. The left sidebar provides various features, and you need to add your WhatsApp number to begin. This integration is crucial as it allows Pabbly Chatflow to facilitate communication between your AI assistant and users on WhatsApp.
2. Creating Your AI Assistant in Pabbly Chatflow
After setting up your WhatsApp number, the next step is to create your AI assistant. Click on the ‘Add Assistant’ button to start. Name your assistant descriptively, such as “AI Loan Advisor for WhatsApp.” This naming will help you identify it later in Pabbly Chatflow.
  • Click the ‘Add Assistant’ button.
  • Enter a descriptive name for your assistant.
  • Select the instruction type as “AI Agent”.
Once created, you will see options to customize the assistant’s behavior. Set the temperature for responses, which controls the creativity level. A temperature of 0.5 is recommended for a balanced approach. This setup is essential for ensuring that Pabbly Chatflow delivers tailored responses to user queries.
3. Configuring Your AI Assistant Settings in Pabbly Chatflow
Next, configure your AI assistant settings within Pabbly Chatflow. You need to enter the OpenAI API token, which is crucial for the AI’s functionality. To obtain this token, go to your OpenAI API keys page and create a new secret key.
  • Navigate to the OpenAI API keys page.
  • Click on “Create New Secret Key”.
  • Copy the generated API key and paste it into Pabbly Chatflow.
After saving the API key, you can also set options for retry attempts and fallback messages. These settings will ensure that your assistant can handle errors gracefully, making it more reliable in providing responses to users through Pabbly Chatflow.
4. Uploading Knowledge Base for AI Loan Advisor in Pabbly Chatflow
The knowledge base is vital for your AI Loan Advisor, as it provides specific information related to loans and eligibility. Create a knowledge base file using Google Docs or any text editor, ensuring it contains all relevant information.
  • Create a knowledge base file in PDF or text format.
  • Ensure the file size is less than 90 MB.
  • Upload the file in the knowledge base section of Pabbly Chatflow.
Once uploaded, this knowledge base will guide your assistant in providing accurate responses to user queries. This step is crucial for enhancing the performance of your AI Loan Advisor within Pabbly Chatflow.
5. Finalizing Your AI Assistant Settings in Pabbly Chatflow
After setting up the knowledge base, you can finalize your assistant’s interface in Pabbly Chatflow. Customize the assistant’s appearance and initial messages to align with your branding. This includes setting headings, subheadings, and footer text.
Once you have made all the necessary adjustments, enable the assistant and save your settings. Your AI Loan Advisor is now ready to interact with users on WhatsApp, providing assistance 24/7 without any manual input.
In this tutorial, we’ve outlined how to build an AI Loan Advisor for WhatsApp using Pabbly Chatflow. By following these steps, you can create a robust assistant that enhances customer engagement and provides valuable loan advice. This powerful tool operates seamlessly, ensuring users receive timely responses and support.
