To start integrating API, Not, Pabi, and other applications, first, you need to access Pabbly Connect. This platform serves as the central hub for all your automation needs.
Visit the Pabbly Connect website and log in to your account. If you are a new user, you can sign up for free. Upon signing in, you will be presented with an intuitive dashboard to manage your integrations.
2. Creating Your AI Assistant with Pabbly Connect
Once you are logged into Pabbly Connect, navigate to the AI assistant section. Here, you can start creating your AI assistant tailored to your business needs.
  • Select the type of AI assistant you want to create.
  • Configure the AI settings, including temperature and model selection.
  • Enter your API key from OpenAI to connect your assistant.
After configuring your AI assistant, you can upload a knowledge base document that will act as the brain of your assistant, enabling it to provide accurate responses to customer queries.
In this section, you will set the various parameters for your AI assistant within Pabbly Connect. This includes defining the creativity level of the AI responses.
For instance, you can set the temperature to 0.5 for balanced responses. You will also select the AI model, such as GPT-5 mini, and provide the necessary API key. This key is crucial for linking your assistant to the OpenAI services.
Additionally, you can manage settings like header and footer messages, stop keywords, and fallback messages. These settings help refine how your assistant interacts with users, ensuring a seamless experience.
4. Embedding Your AI Assistant into Your Website
After creating and configuring your AI assistant, you can embed it into your website using Pabbly Connect. This allows your customers to interact with the assistant directly.
  • Click on the embed button in the Pabbly Connect interface.
  • Copy the provided script code.
  • Paste the code into your website’s HTML where you want the assistant to appear.
Once embedded, your AI assistant will be active and ready to assist customers with their queries in real time, enhancing customer interaction.
5. Enabling Your AI Assistant for Customer Interactions
Finally, you need to enable your AI assistant for customer interactions through Pabbly Connect. This is a crucial step to ensure that your assistant is operational.
Go to the inbox settings and enable AI auto replies. You can choose to activate the assistant for all contacts or specific chats. This flexibility allows you to control how and when your assistant engages with users.
Once enabled, your AI assistant will automatically respond to customer messages, providing timely and accurate information based on the knowledge base you uploaded earlier.
Using Pabbly Connect to integrate API, Not, Pabi, and other applications allows you to create a powerful AI assistant for your business. This tutorial covered the steps to access, configure, and enable your AI assistant effectively. Start automating your customer interactions today!
