To begin integrating Pabbly, Chat Flow, and Open AI, first access Pabbly Connect by navigating to pabbly.com/chatflow in your browser. This will take you directly to the Pabbly Chat Flow homepage, where you can either log in or sign up for a free trial.
If you are a new user, click on the “Sign Up Free” button to create your account. Existing users can log in directly. Once logged in, you will see various options available under the Pabbly applications.
2. Setting Up Pabbly Chat Flow for Your Business
After accessing Pabbly Connect, select “Pabbly Chat Flow” from the applications menu. Click on the “Access Now” button to enter the Chat Flow dashboard. Here, you can create and manage your chatbots.
  • Choose the WhatsApp number you want to link.
  • Follow the prompts to set up your chatbot.
  • Ensure your WhatsApp account is verified to use the chatbot features.
Once set up, you can start customizing your chatbot to enhance customer interactions. This is where Pabbly Connect plays a crucial role in ensuring seamless communication through WhatsApp.
3. Creating an AI Assistant with Pabbly Chatbot
To create a new AI assistant, navigate to the “Pabbly Chatbot” section within Pabbly Connect. Click on the “Add Assistant” button, name your assistant, and then click “Add” again to proceed. This action will take you to the assistant setup flow.
In the setup flow, select the type of instructions you want to give your assistant. You can either input your own prompts or choose from predefined examples. For instance, if you select “Sales Agent,” the instructions will automatically update to guide your assistant’s responses.
  • Adjust the temperature setting to control the creativity of responses.
  • Choose Open AI as the service provider and select the model you wish to use.
  • Input your Open AI API key to connect your assistant with the AI service.
This integration through Pabbly Connect allows for real-time interaction with customers, providing them with accurate and prompt responses.
4. Configuring Your AI Assistant Settings
Once your AI assistant is created, you will need to configure various settings to optimize its performance. Start by setting the header and footer messages that will be displayed to users. These settings help in establishing a professional tone in your interactions.
Next, you can define stop keywords that will trigger a pause in the assistant’s responses. For example, if a user types “human,” the assistant will stop responding, allowing a human agent to take over. This feature is essential for managing complex customer inquiries effectively.
  • Specify the fallback message for instances when the assistant cannot provide an answer.
  • Upload a knowledge base file to enhance the assistant’s response accuracy.
  • Customize the interface settings, including branding elements like logos and colors.
These configurations are made possible through Pabbly Connect, ensuring that your assistant is tailored to meet your business needs.
5. Activating Your AI Assistant for WhatsApp
After configuring your AI assistant, it’s time to activate it for WhatsApp conversations. Navigate to the inbox settings within Pabbly Connect and enable the option that allows your AI assistant to respond to chats.
Choose the contacts from your list that you want the assistant to handle. You can either assign the assistant to all contacts or select specific ones. Click on the “Save” button to finalize your settings.
  • Test the assistant by initiating a conversation on WhatsApp.
  • Monitor the responses to ensure it’s functioning as intended.
  • Make adjustments based on user feedback to improve performance.
With Pabbly Connect, your AI assistant is now fully operational, ready to enhance customer engagement and streamline your business processes.
This tutorial demonstrates how to use Pabbly Connect to integrate Pabbly, Chat Flow, and Open AI effectively. By following these steps, you can create a powerful AI assistant that enhances customer interactions and automates responses.
Utilizing Pabbly Connect not only streamlines your workflow but also improves customer satisfaction through timely and accurate assistance.
