To begin using Pabbly Chatflow, first visit the official site by entering www.pabbly.com/chatflow in your browser. This platform allows you to create a WhatsApp chatbot quickly and efficiently.
Once on the site, you can sign in if you are an existing user or click on “Sign Up Free” if you are new. Signing up provides you with credits to explore the features of Pabbly Chatflow before committing to a subscription.
2. Adding Your WhatsApp Number to Pabbly Chatflow
After signing into Pabbly Chatflow, the dashboard will display your account details. To integrate your WhatsApp, click on “Add WhatsApp Number”. This step is crucial for enabling the chatbot to communicate via WhatsApp.
- Select “WhatsApp Connect” as your preferred method.
- Alternatively, you can use a manual token to connect.
By following these steps, you will successfully link your WhatsApp account to Pabbly Chatflow, allowing for seamless chatbot functionality.
3. Creating an AI Assistant in Pabbly Chatflow
To set up your WhatsApp chatbot, navigate to the AI Assistant section in Pabbly Chatflow. Click on “Add AI Assistant” and name it according to your business needs, such as “Design Agency”.
Next, choose the instruction type as “AI Agent”. This selection automatically populates necessary instructions, which you can customize further. Adjust the AI configuration settings for creative responses, setting it to 0.8 for a balanced output.
- Select OpenAI as the AI to use.
- Enter the API key obtained from OpenAI.
- Provide fallback messages and stop keywords for user queries.
After setting these configurations, save your AI assistant to make it active. This process is essential for ensuring that your chatbot can effectively respond to user inquiries.
4. Uploading Knowledge Base for Your AI Assistant
In Pabbly Chatflow, it’s vital to provide a knowledge base for your AI assistant to function optimally. You can upload a document containing details about your services, such as packages, pricing, and processes. This information allows the AI to provide accurate responses to user queries.
To upload, click on “Upload File” and select your document. Ensure it is well-structured, covering all necessary aspects of your business. A detailed knowledge base enhances the chatbot’s ability to assist customers effectively.
- Include service descriptions, pricing details, and examples of your work.
- Make sure the document is in .txt or .pdf format.
Once uploaded, your AI assistant will have the necessary information to answer customer inquiries accurately, improving user satisfaction.
5. Assigning the AI Assistant to Contacts in Pabbly Chatflow
After creating your AI assistant in Pabbly Chatflow, the next step is to assign it to your contacts. Navigate to the inbox settings to manage your AI auto-replies. Here, you can select specific groups or all contacts to use the AI assistant.
Enable the AI auto-reply feature and set rules for assignment. You can select lists of contacts and assign the AI assistant accordingly. This functionality ensures that your chatbot is available to assist all relevant contacts.
- Select the AI assistant you created.
- Save the changes to activate the assistant for the chosen contacts.
By following these steps, your AI assistant will be ready to interact with users, providing timely and accurate responses through WhatsApp.
In this tutorial, we explored how to create a WhatsApp chatbot using Pabbly Chatflow, covering everything from accessing the platform to assigning your AI assistant. This process enables efficient automation of conversations, enhancing customer engagement.
