1. Access Pabbly Connect to Begin Integration
To start creating your AI assistant using Pabbly Connect, first, open your Pabbly Connect dashboard. If you are a new user, visit the Pabbly website and sign up for a free trial.
Once you are logged in, ensure your WhatsApp number is connected to your Pabbly Connect account. This is crucial for enabling the integration between WhatsApp and your AI assistant.
2. Create Your AI Assistant in Pabbly Connect
In the Pabbly Connect dashboard, navigate to the assistant feature from the left panel. This is where you can create various types of WhatsApp assistants tailored to your business needs.
  • Click on the plus (+) button to add a new assistant.
  • Select the instruction type as ‘AI agent’ to define how your assistant will interact with users.
  • Set the temperature parameter to control the creativity of your assistant.
After setting the initial parameters, you can proceed to customize your assistant’s behavior and responses. This is where Pabbly Connect truly shines, allowing you to define how your assistant behaves based on your business’s specific needs.
3. Configure AI Settings in Pabbly Connect
Once your assistant is created, you will need to configure several important settings. Start by pasting your OpenAI API key into the designated field in Pabbly Connect. This key allows your assistant to utilize OpenAI’s capabilities.
Next, customize the header and footer messages to improve user interaction. The header message will greet users at the start of the conversation, while the footer message can be used for closing remarks. Additionally, set up stop keywords to enable users to halt the conversation if needed.
  • Define retry attempts for the assistant to respond to users.
  • Customize fallback messages for error handling.
These configurations help in creating a seamless experience for users, ensuring that your AI assistant is both responsive and user-friendly. Pabbly Connect makes it easy to manage these settings effectively.
4. Upload Your Knowledge Base in Pabbly Connect
The next step in setting up your AI assistant is to upload a knowledge base file. This file is crucial as it contains all the information your assistant will use to respond to customer inquiries. Create a Google Docs file with your business information and download it as a PDF.
Ensure that the file size is under 90 MB and in the correct format. In Pabbly Connect, click on the option to add a new file, then drag and drop your knowledge base PDF into the designated area. This upload process is straightforward and helps your assistant become knowledgeable about your offerings.
5. Enable Auto Replies in Pabbly Connect
To finalize your assistant setup, navigate to the inbox settings in Pabbly Connect. Here, enable the AI auto-replies feature to allow your assistant to respond to customer messages automatically.
Select the contact list to which your assistant will be assigned and save the settings. This ensures that your assistant is now active and ready to handle customer inquiries through WhatsApp.
Pabbly Connect streamlines this entire process, making it easy to manage your assistant’s settings and ensure it operates efficiently.
In this tutorial, we explored how to integrate WhatsApp with your AI assistant using Pabbly Connect. By following these steps, you can create an efficient customer service assistant that operates 24/7, enhancing user experience and engagement.
