1. Creating an Automated WhatsApp Assistant with Pabbly Connect
To start building your automated WhatsApp assistant, first, access Pabbly Connect by navigating to pabb.com/chartflow. This platform is essential for integrating WhatsApp with various applications seamlessly.
Once you are on the Pabbly Chartflow page, if you are a new user, click on the “Sign Up Free” button to create an account and receive 100 free credits. Existing users should click on “Sign In” to access their accounts and start creating the assistant.
2. Adding Your WhatsApp Number in Pabbly Connect
The next step involves adding your WhatsApp number to your Pabbly Chartflow account. This is crucial for the assistant to function properly. Follow the instructions provided in the Pabbly documentation to complete this setup.
  • Navigate to the settings section of your Pabbly Chartflow account.
  • Click on the “Add WhatsApp Number” option.
  • Follow the prompts to verify your number.
After successfully adding your WhatsApp number, you are now ready to create your assistant. This integration is made seamless through Pabbly Connect, ensuring that your assistant can communicate effectively.
3. Building Your WhatsApp Assistant in Pabbly Connect
To build your assistant, click on the “Add Assistant” button in Pabbly Chartflow. This step is where you will define the purpose of your assistant, which in this case is to handle admission queries.
After entering a descriptive name, such as “Admission Queries Assistant,” click on the “Create Assistant” button. You will then select the instruction type, which should be set as an AI agent to enable smart responses.
  • Choose the AI agent option for the instruction type.
  • Adjust the temperature setting to control response creativity.
  • Select OpenAI as the model provider.
These settings allow Pabbly Connect to tailor responses to user queries effectively, ensuring a smooth user experience.
4. Configuring the OpenAI API in Pabbly Connect
To enable your assistant to generate responses, you need to configure the OpenAI API. Click on the “Connect” button and enter your API key, which you can generate from your OpenAI account.
Make sure your OpenAI account is set up for billing to generate the API key. After obtaining the key, paste it into the designated field in Pabbly Connect and click “Save” to ensure the settings are applied.
  • Generate a new secret key in your OpenAI account.
  • Copy the key and paste it into Pabbly Connect.
  • Confirm that the API key is saved successfully.
With this configuration, Pabbly Connect acts as the bridge, allowing your assistant to access OpenAI’s capabilities for generating intelligent responses.
5. Finalizing Your WhatsApp Assistant in Pabbly Connect
After configuring the API, you can finalize your assistant settings. This includes setting up welcome messages, footer messages, and defining any stop keywords that will halt the conversation if needed.
Once you have entered all necessary information, click on the “Save Assistant” button to complete the setup. This ensures that your assistant is now ready to handle queries on WhatsApp.
By using Pabbly Connect, you have created a fully automated WhatsApp assistant that can respond to admission queries 24/7 without any manual intervention. This is a significant advantage for any business looking to streamline customer interactions.
In this tutorial, we demonstrated how to create an automated WhatsApp assistant using Pabbly Connect. By following these steps, you can efficiently handle admission queries and enhance your customer service experience.
