To build an AI agent that automates WhatsApp conversations, the first step is to access Pabbly Connect. Begin by visiting the Pabbly website and navigating to the Pabbly Chat Flow section.
Once you are on the Pabbly Chat Flow homepage, you can either log in if you already have an account or sign up for a free trial. After logging in, you will find the option to access all Pabbly applications, including Pabbly Connect.
2. Setting Up Pabbly Chat Flow for WhatsApp
After accessing Pabbly Connect, the next step is to set up Pabbly Chat Flow for your WhatsApp integration. Click on “Access Now” to enter the Pabbly Chat Flow dashboard. Here, you will see options to link your WhatsApp number.
- Click on “Add New Assistant” to create your AI agent.
- Name your assistant and proceed to the next step.
- Select the type of instructions for your assistant from the dropdown menu.
In this section, you’ll configure the AI assistant by selecting settings like the type of instructions and the AI model. This is where Pabbly Connect plays a crucial role in facilitating the integration with WhatsApp.
Now that you’ve set up your assistant, it’s time to configure the AI settings. Begin by selecting the AI model you want to use, such as OpenAI’s GPT-5.2. This selection is important as it determines how the assistant will respond to user inquiries.
Next, set the temperature parameter to control the creativity of the responses. A lower value like 0.4 will yield more focused answers. Make sure to enter your OpenAI API key to enable the assistant to function properly. This key is essential for establishing a connection between Pabbly Connect and OpenAI.
4. Setting Up Knowledge Source for Your AI Agent
To ensure your AI agent provides accurate responses, you need to set up a knowledge source. This can be done by uploading a document that contains all relevant information about your business. Pabbly supports PDF and plain text formats for this purpose.
- Download your business information as a PDF or plain text file.
- Upload the document in the SitePal Lead Chat Flow section of Pabbly Connect.
- Ensure the file contains all necessary details for customer queries.
This knowledge base will empower your AI assistant to respond to customer inquiries effectively, making it a crucial step in the setup process.
5. Activating Your AI Agent for WhatsApp Conversations
Once everything is set up, you need to activate your AI agent. This is done by enabling the assistant in the settings under “Inbound Settings”. Here, you can toggle the auto-reply feature on and select the contacts for which the AI agent will respond.
After saving your settings, your AI agent is now ready to handle WhatsApp conversations automatically. This integration through Pabbly Connect allows for seamless communication with customers, enhancing your business efficiency.
In this tutorial, we explored how to build an AI agent using Pabbly Connect to automate WhatsApp conversations. By following the steps outlined, you can effectively set up your AI assistant to enhance customer interactions and streamline communication.
