1. Accessing Pabbly Connect to Create Your AI Agent
To create an AI agent on WhatsApp, you’ll first need to access Pabbly Connect. This platform serves as the backbone for integrating various applications, allowing you to build seamless workflows.
Log into your Pabbly account and navigate to the Pabbly Chatbot feature. Here, you can initiate the process of creating your AI agent by clicking on the “Add Smart Assistant” button. This is where the integration with Open AI will begin.
2. Setting Up Your AI Agent with Pabbly Chatbot
Once you’ve accessed Pabbly Chatbot, the next step is to configure your AI agent. Click on the “Add Smart Assistant” button and give your assistant a name, such as “Travel Agency AI Agent”. This name will help identify the purpose of your agent.
  • Click on the “Add Smart Assistant” button.
  • Name your assistant appropriately.
  • Choose the type of instruction for your AI agent.
After naming your assistant, select the type of instruction. Choose “AI Agent” to set the behavior and responses of your AI. This is how Pabbly Connect allows you to define how the AI will interact with users, making it crucial for effective communication.
3. Configuring AI Parameters in Pabbly Connect
In this section, you’ll set the parameters for your AI agent, such as temperature and AI provider. The temperature controls the creativity of the responses. A lower temperature results in more stable answers, while a higher temperature allows for more creative responses.
Set the temperature to 0.5 for balanced responses. Next, select Open AI as your AI provider and choose the version, such as GPT-4 Omni. This selection is vital as it determines the capabilities of your AI.
  • Set temperature to 0.5.
  • Select Open AI as the provider.
  • Choose GPT-4 Omni version.
After setting these parameters, you’ll need an API key from Open AI to connect your agent to the AI service. This integration through Pabbly Connect enables your AI to access the necessary data to respond accurately to user queries.
4. Integrating Open AI API with Pabbly Connect
To integrate Open AI API, you’ll need to generate an API key from your Open AI account. Navigate to the API keys section and click on “Add New Secret Key”. This key will link your Pabbly Chatbot with Open AI, facilitating communication.
Once you’ve created the API key, copy it and paste it into the designated field in Pabbly Chatbot. Click on the “Connect” button to establish the link. This step is crucial as it allows your AI agent to utilize Open AI’s features for generating responses.
  • Go to Open AI API keys section.
  • Create a new secret key.
  • Paste the key in Pabbly Chatbot and click “Connect”.
This integration through Pabbly Connect ensures that your AI agent can effectively respond to customer inquiries by leveraging Open AI’s capabilities.
5. Finalizing Your WhatsApp AI Agent Setup
Now that your AI agent is connected to Open AI, it’s time to finalize the setup. You can customize additional settings such as header messages, footer messages, and retry attempts. These settings enhance the user experience by providing clear communication.
For instance, you can add a stop word like “stop” to halt the conversation when needed. After configuring these settings, you can upload a knowledge base file that contains all relevant information for your AI agent.
  • Customize header and footer messages.
  • Set retry attempts for responses.
  • Upload a knowledge base file.
Once everything is set up, click on the “Save Smart Assistant” button to activate your AI agent. This final step through Pabbly Connect makes your AI agent ready to assist customers on WhatsApp, providing automated responses 24/7.
Creating an AI agent on WhatsApp using Pabbly Connect is a straightforward process that enhances customer interaction. By leveraging Pabbly Chatbot and Open AI, businesses can automate responses effectively, ensuring better service.
