To build your WhatsApp sales funnel, the first step is accessing Pabbly Connect. Start by visiting the Pabbly website and navigating to the Pabbly Chatflow section. This platform enables seamless integration between WhatsApp and your marketing strategies.
Once on the homepage, if you are a new user, click on “Sign Up for Free”; if you are an existing user, simply log in. After signing in, you will see a dashboard where you can access all Pabbly applications. Click on “Access Now” for Pabbly Chatflow to proceed.
2. Creating Message Templates in Pabbly Chatflow
Before sending broadcasts, you need to create a message template in Pabbly Connect. This template will be used for sending WhatsApp messages to your customers. Navigate to the template section and create your desired message.
  • Choose a template type: approved, pending, draft, or rejected.
  • Attach images or other media to enhance your message.
Once your template is ready and approved, you can use it for your WhatsApp broadcasts. Ensure that your message aligns with the promotional content you wish to share.
3. Setting Up a WhatsApp Broadcast with Pabbly Connect
To set up a WhatsApp broadcast, go to the broadcast section within Pabbly Connect. Here, you can view existing broadcasts and create new ones. Click on the “Add Broadcast” button to initiate the process.
In the broadcast setup, select the broadcast type as “Broadcast Campaign”. Name your campaign, for example, “New Laundry Offer”. Next, you will be prompted to choose your audience. You can either select an existing contact list or upload a CSV file with customer details from your Google Sheets.
4. Refining Audience and Scheduling Messages
After setting up your broadcast in Pabbly Connect, you can refine your audience. This allows you to exclude certain contacts from receiving the message. You can exclude entire lists or specific contacts, ensuring that your broadcast reaches the intended audience.
  • Select message type: regular or template-based.
  • Test your broadcast message by sending it to your WhatsApp number.
Once satisfied with your setup, you can choose to send the message immediately or schedule it for a future date and time. Make sure to select a valid future date to avoid instant sending.
5. Monitoring Broadcast Results and Resending Failed Messages
After your broadcast is sent, you can monitor its performance through Pabbly Connect. The dashboard will show you metrics such as sent, delivered, read, and pending messages. This data is crucial for understanding the effectiveness of your sales funnel.
If any messages fail to deliver, you can easily resend them to failed contacts using the resend option available in the dashboard. This ensures that your message reaches as many customers as possible.
In summary, using Pabbly Connect to build a WhatsApp sales funnel through broadcast automation is a straightforward process. By following these steps, you can efficiently reach your customers and enhance your marketing strategy. Automate your communications today for better engagement!
