To start integrating Pabbly Chatflow and Pabbly Chatbot with YouTube and Build Mart, you need to access Pabbly Connect. Begin by visiting the Pabbly website and creating a free account if you haven’t already.
Once logged in, navigate to the dashboard where you can find options to create new integrations. Select the Pabbly Connect option to get started. This platform will enable you to connect various applications seamlessly.
2. Creating a Chatbot Flow with Pabbly Chatflow
In this section, we will create a chatbot flow using Pabbly Connect. After accessing the dashboard, click on the “Flows” feature located on the left sidebar. Here, you can add a new flow by clicking on the “Add Flow” button.
Once on the new flow page, you will need to name your flow. After naming, you can set up the trigger event for your chatbot. Follow these steps to create your chatbot flow:
- Select the trigger event as “Keyword”.
- Enter keywords like “hello” and “hi” that users might send via WhatsApp.
- Add a welcome message using the “Text” button.
Now, your chatbot is ready to respond to greetings from customers.
3. Customizing Chatbot Responses with User Inputs
Next, you will customize responses based on user inputs using Pabbly Connect. After setting up the welcome message, you can add quick response buttons like “Find Materials” and “Contact Team”. This allows users to navigate easily through the chatbot.
To add these buttons, click on the “Add” button and enter the button names. After that, connect the buttons to their respective actions. For example, when a user clicks “Find Materials”, the bot should ask, “What materials are you looking for?” Here’s how to do it:
- Use the “List Node” to ask about materials.
- Enter available material types as options.
- Connect this node to the button action.
This setup ensures personalized interaction with each customer based on their selections.
4. Finalizing the Chatbot Flow with Confirmation
Finally, you will finalize your chatbot flow using Pabbly Connect. After collecting all user inputs, you can send a confirmation message summarizing their choices. This enhances the user experience by providing clarity.
To do this, add a text node that includes placeholders for user inputs like material type, quantity, and contact details. This can be achieved by using the dollar sign notation for dynamic fields. Here’s how to complete your flow:
- Create a final message node summarizing the user’s input.
- Add quick reply buttons for “Confirm Details” and “Go Back”.
- Connect these buttons to their respective nodes for smooth navigation.
This setup will ensure that your customers feel acknowledged and informed about their requests.
5. Conclusion: Automate Your Business with Pabbly Connect
In this tutorial, we explored how to automate WhatsApp conversations using Pabbly Connect, Pabbly Chatflow, and Pabbly Chatbot. By following the steps outlined, you can create a fully functional chatbot that enhances customer interaction with your business.
Utilizing these tools not only streamlines communication but also improves customer satisfaction. Start building your automated WhatsApp bot today and experience the benefits of enhanced customer engagement.
