1. Accessing Pabbly Connect for Your WhatsApp Chatbot
To start automating bookings with a WhatsApp chatbot, you need to access Pabbly Connect. This integration platform is essential for connecting various applications seamlessly.
Once you have your account set up, log in to Pabbly Connect. From the dashboard, you can begin creating workflows that connect Pabbly Chatbot with WhatsApp to handle booking requests efficiently.
2. Setting Up Your Pabbly Chatbot
Next, you will create your WhatsApp chatbot using the Pabbly Chatbot tool. Navigate to chatflow.pabbly.com and log into your account. Ensure your WhatsApp number is linked to your Pabbly account.
  • Select “Flows” from the sidebar to access the flow builder.
  • Choose a trigger event to start your chatbot.
  • Create a template message for your booking event.
By following these steps, you can set up your chatbot to respond to booking requests effectively, utilizing Pabbly Connect for integration.
3. Creating a Booking Flow in Pabbly Chatbot
In this section, you will define the booking flow for your WhatsApp chatbot. Use Pabbly Chatbot to set up the necessary questions and responses for gathering user information.
Start by creating a prompt that asks for the user’s full name. Then, configure the chatbot to follow up with questions about their email and ticket type. This is where Pabbly Connect plays a crucial role in managing the data flow.
  • Ask for the user’s full name and store it in a custom contact field.
  • Request the user’s email address for confirmation.
  • Allow the user to select their desired ticket type (Regular or VIP).
These steps ensure that your chatbot can collect all necessary information for bookings, with Pabbly Connect facilitating the integration of this data into your systems.
4. Integrating Google Sheets Using Pabbly Connect
After gathering user information, the next step is to save this data into Google Sheets. This is where Pabbly Connect comes into play as the integration bridge between your chatbot and Google Sheets.
Set up a webhook in Pabbly Connect to receive the data from your chatbot. Choose the POST method to send the user’s name, email, and ticket type to your Google Sheets.
Make sure to define the parameters in your webhook settings so that the data is correctly mapped to the relevant columns in your Google Sheets. This ensures that all booking details are stored accurately and can be accessed later.
5. Finalizing Your WhatsApp Chatbot Setup
Once the integration is complete, test your WhatsApp chatbot to ensure it functions as intended. Use Pabbly Connect to monitor the data flow and confirm that all information is being captured correctly.
Finally, provide a confirmation message to the user after their booking is successfully recorded. This enhances the user experience and ensures they feel valued.
With everything set up, you can now automate bookings through WhatsApp effectively. Remember, Pabbly Connect is central to this process, enabling seamless data transfer between applications.
Building a WhatsApp chatbot using Pabbly Connect allows for efficient booking automation. By integrating Pabbly Chatbot and Google Sheets, you streamline your booking process, enhancing customer experience.
