1. Setting Up Pabbly Connect for WhatsApp Chatbot
To build a WhatsApp Chatbot, you first need to access Pabbly Connect. This platform serves as the central hub for integrating various applications, including Pabbly Chat Flow and WhatsApp.
Once you log into your Pabbly Connect account, navigate to the dashboard. Here, you will find options to create a new workflow, which is essential for setting up your chatbot. Select the option to create a new workflow and name it accordingly.
2. Creating Your Chat Flow in Pabbly Chat Flow
After setting up Pabbly Connect, the next step is to create your chat flow using Pabbly Chat Flow. This tool allows you to design the conversation your chatbot will have with customers.
In the Pabbly Chat Flow interface, you will see buttons on the left side to help you design your chat flow. Start by selecting the trigger event. Here are the steps you need to follow:
  • Click on the trigger event button.
  • Choose the “Template Selected” trigger.
  • Select the product restock alert template.
This template will initiate your chatbot’s flow, sending engaging messages to your customers via WhatsApp.
3. Designing Chatbot Responses with Pabbly Chatbot
Utilizing Pabbly Chatbot, you can customize responses that your bot will send. This includes adding personalized messages and buttons that guide users through their options.
For instance, when a customer interacts with the bot, they will receive a message like: “Great choice! The Glow Muse Hydrating Face Serum is now available.” You can add quick reply buttons such as “Buy Now” and “View Details.” Here’s how:
  • Add a text button for the “Buy Now” action.
  • Input the message content in the designated field.
  • Link this button to the next step in the flow.
> This structure allows your chatbot to handle customer inquiries effectively and keep the conversation flowing smoothly.
4. Collecting Customer Information
In this step, you will configure Pabbly Connect to collect essential customer information, such as their name, contact number, and product quantity. This is crucial for processing orders accurately.
To do this, you will add questions to your chatbot flow. For example, when a customer clicks “Buy Now,” the bot can ask for their full name. Here’s how to set it up:
  • Select the “Ask Question” button in the flow.
  • Enter the question in the provided field.
  • Designate the response field as “Full Name”.
> This process will ensure that your bot captures all necessary details from the customer effectively, enhancing the overall user experience.
5. Finalizing Your Chatbot Flow
Once you have configured the responses and customer data collection, it’s time to finalize your chatbot flow in Pabbly Connect. This step ensures that your bot is ready to engage with customers.
Make sure to activate the flow and save your settings. After activation, your WhatsApp chatbot will be live and operational, ready to assist customers around the clock. Here are the final steps:
  • Toggle the activation switch to enable the flow.
  • Click the save button to keep your settings.
> With these steps completed, your WhatsApp Chatbot is fully functional and ready to serve your business needs.
In this tutorial, you learned how to build a WhatsApp Chatbot using Pabbly Connect, Pabbly Chat Flow, and Glow Muse. This integration allows you to automate customer interactions effectively, enhancing your business operations.
