1. Accessing Pabbly Connect for Your WhatsApp Chatbot
To create a WhatsApp chatbot, you first need to access Pabbly Connect. Start by visiting the Pabbly website and signing in to your account. If you’re new, you can sign up for free and explore the features offered.
Once logged in, navigate to the Pabbly Chat Flow section. This is where you will set up your WhatsApp chatbot. You will see options to start a WhatsApp number connection, which is crucial for integrating your chatbot with WhatsApp.
2. Creating an AI Assistant in Pabbly Connect
In this step, you will create an AI assistant using Pabbly Connect. Go to the AI Assistant section and click on “Add AI Assistant”. Name your assistant, such as “WhatsApp Chatbot for Bakery Orders”. This assistant will handle customer queries automatically.
  • Select AI instruction type as AI agent.
  • Set the AI temperature to 0.8 for creative responses.
  • Choose OpenAI as the AI to use.
After setting these configurations, you will need to enter your OpenAI API key. This key is essential for your AI assistant to function correctly. Once you have entered the key, click on “Update Key” to save your settings.
3. Configuring AI Assistant Settings in Pabbly Connect
Now, you will configure the settings for your AI assistant in Pabbly Connect. This includes adding a header message, footer message, and stop keywords. The stop keywords are crucial for managing conversations effectively, allowing users to escalate queries to human support.
  • Set the retry attempts for unanswered queries (1-10).
  • Upload a knowledge base file with product details.
  • Add fallback messages for unresolved queries.
Make sure to save all your configurations. This setup ensures that your AI assistant can respond accurately to customer queries based on the knowledge base you provided, enhancing customer interaction.
4. Assigning the AI Assistant to Contacts Using Pabbly Connect
In this section, you will assign the AI assistant to specific contacts using Pabbly Connect. Navigate to the inbox settings and enable AI auto-replies. This feature allows your AI assistant to automatically respond to customer queries without manual intervention.
Select the contacts or groups you want to assign the AI assistant to. You can add rules to specify which AI assistant responds to which contact list. This is essential for managing multiple customer interactions efficiently.
5. Testing Your WhatsApp Chatbot with Pabbly Connect
Finally, it’s time to test your WhatsApp chatbot created through Pabbly Connect. Open your WhatsApp and send a query to your chatbot. For instance, you can ask about cake availability or customization options. The AI assistant should respond promptly with the relevant details.
Monitor the responses to ensure that your chatbot is functioning correctly. If everything works as expected, your WhatsApp chatbot is now ready to assist customers efficiently, automating your bakery business interactions.
In this tutorial, we explored how to create a WhatsApp chatbot for your bakery using Pabbly Connect. This integration automates customer interactions, enhancing service efficiency and customer satisfaction.
