To start integrating WhatsApp chatbots, you first need to access Pabbly Connect. This platform allows seamless automation between various applications, including WhatsApp.
Once you log in to your Pabbly Connect account, navigate to the dashboard where you can create new workflows. Make sure to select the appropriate application for the integration.
2. Setting Up Your WhatsApp Chatbot Flow with Pabbly Connect
In this section, we will create a WhatsApp chatbot flow using Pabbly Connect. Begin by selecting the “Add Flow” button on the Pabbly dashboard.
  • Click on “Add Flow” to create a new chatbot flow.
  • Name your flow based on the services you provide.
  • Select the trigger event to start the flow.
Once the flow is created, you can start adding various components like messages and actions to enhance the functionality of your chatbot.
3. Adding Keywords and Messages in Pabbly Connect
The next step involves adding keywords that will trigger responses from your WhatsApp chatbot. In Pabbly Connect, you can easily add these keywords.
For instance, you can enter keywords like “visa” or “consultation” that users might send. Once a keyword is detected, your chatbot will send a welcome message.
  • Select the “List” button to create options for users.
  • Enter your welcome message in the body section.
  • Add multiple visa options for users to choose from.
This setup will ensure that your chatbot can effectively guide users through their queries by providing relevant options.
4. Collecting User Information with Pabbly Connect
After the initial interaction, your chatbot needs to collect user information. This is where Pabbly Connect excels, allowing you to gather essential data from users.
Ask users for their full name, contact number, and email address through the chatbot. You can set up these questions using the “Ask Question” feature in Pabbly Connect.
  • Use the “Ask Question” feature to prompt users for their details.
  • Set validation messages for incorrect formats.
  • Collect additional information like visa type and qualification.
This process ensures that you have all the necessary information to assist your clients effectively.
5. Finalizing Your WhatsApp Chatbot with Pabbly Connect
Once you’ve collected all the necessary user information, it’s time to finalize your chatbot flow. In Pabbly Connect, you can create a personalized confirmation message for users.
Your confirmation message should include details like the visa type, country, and user contact information. This ensures that users receive a tailored response based on their input.
  • Create a confirmation message using the “Text” button.
  • Use contact custom fields to personalize messages.
  • Add a button for users to contact the team directly.
Finally, ensure to save your flow and activate it for immediate use. With Pabbly Connect, your WhatsApp chatbot is now fully functional and ready to assist clients.
This tutorial demonstrated how to integrate a WhatsApp chatbot using Pabbly Connect. By following the outlined steps, you can create an automated system that enhances client interaction and provides instant support.
