To start integrating WhatsApp with Google Sheets, you need to access Pabbly Connect. Begin by visiting the Pabbly Connect website and signing up or logging in if you are an existing user.
Once you are logged in, you can create a new workflow. This workflow will allow you to connect WhatsApp messages to Google Sheets seamlessly. Make sure you have your WhatsApp number ready to link with Pabbly Connect.
2. Creating a Flow in Pabbly Connect
In this section, we will create a flow that triggers when a user sends a specific keyword on WhatsApp. This flow will handle event registrations. To start, access the flow section in your dashboard and click on the “Add Flow” button.
- Select a trigger event, such as receiving a keyword.
- Enter keywords like “interested” to initiate the flow.
- Use the drag-and-drop feature to build your flow.
After setting up the trigger, you can add actions like sending welcome messages. This is where Pabbly Connect shines, as it allows you to automate responses based on user input.
3. Building a WhatsApp Chatbot with Pabbly Connect
Now that we have our flow, let’s build the WhatsApp chatbot. Use Pabbly Connect to create messages that guide users through the registration process. Start by adding a text box that welcomes users and provides options for event details or registration.
Next, link buttons to specific actions. For example, clicking the “Register for Event” button should prompt users for their name and email. This interaction is crucial for gathering user information, and Pabbly Connect helps manage this flow effectively.
4. Using API Requests to Capture Data
To capture user data and store it in Google Sheets, you will need to set up an API request in Pabbly Connect. After users confirm their registration, the API will send their details to Google Sheets.
This process involves dragging the API request node into your flow and configuring it to send data to your Google Sheets. Make sure to enter the correct webhook URL generated by Pabbly Connect during the workflow setup.
- Select the method as “GET” to receive data.
- Add keys for user data like name and email.
- Test the API to ensure it captures the data correctly.
Once set up, you can confirm the data is successfully sent to Google Sheets, showcasing the power of Pabbly Connect in automating data capture.
5. Finalizing Your WhatsApp Chatbot
With everything set up, it’s time to finalize your WhatsApp chatbot. Make sure all connections in your flow are working correctly. Test the entire process from sending a keyword to receiving confirmation messages.
After confirming that everything is functioning as expected, give your bot a name and activate it. This is the final step in utilizing Pabbly Connect to streamline your event registration process through WhatsApp and Google Sheets.
In this tutorial, we explored how to integrate WhatsApp with Google Sheets using Pabbly Connect. By following these steps, you can automate event registrations seamlessly and enhance user experience.
