To start automating WhatsApp appointments, first access Pabbly Connect by visiting the official Pabbly Chartflow page. This tool is essential for integrating various applications seamlessly.
Once on the page, click on the ‘Sign Up Free’ option if you are new or ‘Sign In’ if you are an existing user. After logging in, navigate to the Pabbly Chartflow dashboard where you can begin creating your WhatsApp chatbot.
2. Setting Up Your WhatsApp Chatbot Using Pabbly Connect
In this section, you will create a WhatsApp chatbot that automates appointment bookings. Start by clicking on the ‘Add Flow’ button in Pabbly Connect to initiate a new flow.
  • Name your flow (e.g., “WhatsApp Chatbot for Clinic”).
  • Select the trigger event, which will be based on keywords.
  • Enter keywords such as ‘hi’ and ‘book appointment’ to trigger responses.
After entering your keywords, click ‘Save’ to ensure your flow is active. This setup allows your chatbot to respond instantly when users send these keywords.
3. Creating Responses in Pabbly Connect
Now that your flow is set up, it’s time to create responses for the chatbot. In Pabbly Connect, you can customize the messages that users will receive when they interact with your WhatsApp chatbot.
Start by adding a media button to send a welcome message along with an image. Then, add a text button to greet users and provide a quick reply option for booking appointments. The message can be something like, “Hello! Welcome to Care Plus Clinic. How can I assist you today?”
  • Add a button for users to select departments (e.g., General Physician, Dentist).
  • Ensure that each option links back to the flow for seamless navigation.
This structured response setup ensures that users have a smooth experience when booking appointments through WhatsApp.
4. Capturing User Information for Appointments
Once your chatbot is greeting users, the next step is to capture their information for appointment bookings. Using Pabbly Connect, you can set up fields to collect user details such as their full name, contact number, and preferred appointment date.
Utilize the ‘Ask Question’ feature to prompt users for their full name and contact number. You can set the format for each question to ensure the data is collected correctly. For example:
  • Ask for the full name in a text format.
  • Request the contact number in a numeric format.
  • Inquire about the preferred date and time for the appointment.
This method allows your chatbot to gather all necessary information before confirming the appointment with the user.
5. Finalizing Appointment Confirmation with Pabbly Connect
After capturing user details, it’s crucial to send a confirmation message. In Pabbly Connect, you can create a dynamic response that includes the user’s inputs, ensuring a personalized experience.
Use the ‘Text Button’ feature to send a message like, “Your appointment for [Service Type] with [Full Name] on [Date] at [Time] is confirmed!”. This message will dynamically include the user’s provided details, making them feel valued.
Finally, save your flow in Pabbly Connect to activate the chatbot. This automated system will now handle appointment bookings 24/7 without needing manual intervention.
By leveraging Pabbly Connect, you can automate WhatsApp appointment bookings seamlessly. This tutorial has guided you through the steps to set up your own chatbot for efficient patient management. With this system, you can enhance your clinic’s operational efficiency and improve patient engagement.
