To start using Pabbly Connect for WhatsApp integration, open your web browser and go to pabbly.com/chatflow. This is where you will find the Pabbly Chat Flow platform.
If you are a new user, click on “Sign Up Free” to create an account. Existing users can simply log in to access their dashboard. Once logged in, navigate to the “All Pabbly Applications” section and click on “Access Now” under Pabbly Chat Flow.
2. Creating a Message Template in Pabbly Chat Flow
Before sending WhatsApp messages, you need to create a message template in Pabbly Connect. This template will be used for your broadcasts. Under the “Templates” section, you will see various categories of templates.
  • Choose a template that suits your messaging needs.
  • Make sure it is approved by Meta for WhatsApp use.
  • Add any media or images to enhance your message.
Once your template is ready, ensure it is saved and approved. This is crucial as only approved templates can be used for sending messages through WhatsApp.
3. Setting Up WhatsApp Broadcasts Using Pabbly Connect
To initiate a broadcast, go to the “Broadcast” section in Pabbly Connect. Here, you can see options for creating a new broadcast. Click on the “Add Broadcast” button to start.
When prompted, select the broadcast type as “Campaign Broadcast”. Give your broadcast a name according to your requirements. You will also need to choose your audience:
  • If you have existing contacts, select the first option.
  • If using a CSV file, upload it using the import button.
After selecting your audience, you can refine it by excluding certain contacts if needed. This allows you to customize who receives your messages effectively.
4. Testing and Scheduling Your WhatsApp Broadcast
Once your broadcast is set up in Pabbly Connect, it’s crucial to test it before sending it out. You can send a test message to your own WhatsApp number to see how it appears.
To do this, enter your contact name and number, then click on “Send Test Message”. You should receive a confirmation that the test message was sent successfully. After testing, you can choose to schedule your broadcast. Select a date and time for when you want the message to be sent out:
  • Select a future date and time to schedule.
  • Ensure the time is not in the past to avoid immediate sending.
Once everything is set, click on “Create Broadcast” to finalize your settings. Your broadcast will now be scheduled and ready to go.
5. Monitoring the Results of Your Broadcast
After your broadcast has been sent using Pabbly Connect, you can monitor its performance. This includes statistics on delivered, read, and failed messages, which can help you assess the effectiveness of your communication.
In the broadcast section, you will find detailed insights into how many messages were sent and their status. If any messages failed to send, you can reattempt sending them easily. This feature allows you to ensure that your audience receives your messages:
  • View statistics such as delivered, read, and failed counts.
  • Use the resend option for failed messages.
This monitoring process is crucial for understanding the impact of your WhatsApp broadcasts and improving future communications.
In this tutorial, we explored how to use Pabbly Connect to automate WhatsApp broadcasts effectively. By following the steps outlined, you can streamline your messaging process and enhance your business communications.
