1. Creating a WhatsApp Chatbot Using Pabbly Connect
Creating a WhatsApp chatbot using Pabbly Connect is essential for managing customer requests efficiently. This automation tool allows you to set up a bot that can greet customers, provide options, and collect details seamlessly.
To start, access the Pabbly Chatflow by entering the URL in your browser. You will see options to sign up or sign in. New users can sign up for free and receive 100 free credits monthly to explore the features of Pabbly Connect.
2. Setting Up Your Chatflow with Pabbly Connect
After signing in, navigate to the flow page within Pabbly Connect. This page is where you will create your WhatsApp chatbot. You can start by dragging and dropping the message and action blocks to build the flow.
  • Select the trigger event for your chatbot.
  • Choose keywords that will initiate the chatbot conversation.
  • Create welcome messages and buttons for user interaction.
These steps will ensure that your WhatsApp chatbot is equipped to handle customer inquiries effectively through Pabbly Connect.
3. Building the Chatbot Flow in Pabbly Connect
In this section, you will build the core flow of your WhatsApp chatbot. Start by defining the messages that will be sent to users when they initiate a conversation. Use the message block to create a welcome message and add buttons for user options.
For example, create a button labeled “Explore Courses” that will lead users to a list of available courses. This button should be set as a quick reply type. By doing this, you can efficiently guide users through your offerings using Pabbly Connect.
4. Collecting Customer Details with Pabbly Connect
Once users select a course, your chatbot needs to collect their details. Use the ask question node to prompt users for their full name, city, and preferred timing for sessions. Each response should be linked to custom fields in Pabbly Connect.
  • Ask for the full name and store it in a custom field.
  • Request the user’s city and preferred timing.
  • Provide a confirmation message summarizing their inputs.
This process enhances customer interaction and provides personalized responses through the automation capabilities of Pabbly Connect.
5. Finalizing Your Chatbot with Pabbly Connect
After setting up the flow and collecting customer details, the final step is to save your chatbot flow in Pabbly Connect. This ensures that all your configurations are stored and ready for use.
By following these steps, you have successfully created a WhatsApp chatbot that can manage daily customer requests. This automation can significantly improve your business’s response time and customer satisfaction.
In this tutorial, we explored how to integrate Pabi and Pabbly Chat using Pabbly Connect. By following the detailed steps, you can create an efficient WhatsApp chatbot to enhance customer management and support.
