To start creating a WhatsApp chatbot, you need to access Pabbly Connect. Simply open a new tab in your browser and type in Pabbly.com. This will direct you to the Pabbly website where you can explore various features.
Once on the homepage, look for the Pabbly Connect option and click on it. You will need to sign in or create a new account. Pabbly Connect acts as the central platform for integrating WhatsApp with other applications seamlessly.
2. Creating Your WhatsApp Chatbot Using Pabbly Connect
After logging into Pabbly Connect, you can start creating your WhatsApp chatbot. Navigate to the chatbot section and select the option to create a new assistant. This assistant will handle customer inquiries automatically.
  • Choose a name for your assistant, such as “Product Inquiries”.
  • Select the type of AI agent you want to create, like customer support or sales.
  • Set the AI configuration, including the temperature settings for responses.
By following these steps in Pabbly Connect, you can create an efficient chatbot that responds to customer queries automatically. This ensures that your customers receive timely responses without manual intervention.
3. Connecting Your WhatsApp Number to Pabbly Connect
Next, you need to connect your WhatsApp number to Pabbly Connect. Go to the settings and find the option to add your WhatsApp number. If you are using a WhatsApp Business account, you can connect it directly.
Ensure that your WhatsApp number is verified and active. This step is crucial because it allows Pabbly Connect to send and receive messages through your WhatsApp account, enabling the chatbot functionality.
4. Configuring Your AI Assistant in Pabbly Connect
Once your WhatsApp number is connected, you can configure your AI assistant further. In Pabbly Connect, access the AI assistant settings where you can set the header and footer messages, as well as fallback messages for when the AI cannot answer a query.
Additionally, you need to upload a knowledge source file that contains all relevant information about your products and services. This file will guide the AI in providing accurate responses to customer inquiries.
  • Create a Google Doc with all necessary details about your products.
  • Download the document in PDF or TXT format.
  • Upload this file to your Pabbly Connect account.
This configuration is essential for ensuring that your AI assistant can effectively respond to customer inquiries based on the knowledge you provide.
5. Assigning Your AI Assistant to Customer Queries
Finally, you can assign your AI assistant to handle customer queries. In Pabbly Connect, navigate to the inbox settings and enable AI auto-reply. This allows the assistant to respond to any incoming messages automatically.
You can also choose to assign the assistant to specific contacts or enable it for all incoming messages. This flexibility ensures that your customers always receive timely responses, regardless of the volume of inquiries.
With Pabbly Connect, automating your customer inquiries through WhatsApp becomes a seamless process, allowing you to focus more on your business.
In this tutorial, we demonstrated how to integrate WhatsApp with Pabbly Connect to create a fully functional chatbot. By following these steps, you can automate customer inquiries efficiently and enhance your business operations.
