1. Accessing Pabbly Connect for WhatsApp AI Assistant
To create a WhatsApp AI assistant, you first need to access Pabbly Connect. Start by searching for pabbly.com/chatflow in your browser. This will take you to the Pabbly Chat Flow homepage, where you can sign up or log in if you’re an existing user.
Once logged in, you will see all Pabbly applications. Click on “Access Now” under Pabbly Chat Flow to enter the dashboard. Here, you can manage your WhatsApp number and begin setting up your AI assistant.
2. Creating Your WhatsApp AI Assistant Using Pabbly Connect
With Pabbly Connect, creating a WhatsApp AI assistant is straightforward. Navigate to the AI Assistant feature within Pabbly Chat Flow. Click on the “Add” button to create a new assistant. You will be prompted to name your assistant and then directed to a flow window.
  • Select the instruction type, choosing from options like AI agent or customer support agent.
  • Configure AI settings such as temperature and model type, using options like OpenAI’s GPT 5.2.
  • Enter your OpenAI API key to connect it with your assistant.
After setting these configurations, proceed to add a header message or footer message as required. This customization allows for a personalized touch in your assistant’s responses.
Configuring AI settings is crucial for your WhatsApp AI assistant’s performance. Within Pabbly Connect, you can adjust parameters like temperature to control the creativity of responses. A lower temperature results in more focused answers, while a higher temperature allows for more creative interactions.
Additionally, you can set stop keywords that will halt the assistant’s responses when triggered. For example, typing “human” in the chat will prompt the assistant to stop responding, indicating that a human should take over.
  • Specify the number of retry attempts if the assistant fails to respond correctly.
  • Provide fallback messages to be sent when the API does not respond adequately.
  • Upload a knowledge source document to ensure accurate responses from the assistant.
By meticulously configuring these settings in Pabbly Connect, you enhance the assistant’s capability to address customer queries effectively.
4. Styling Your WhatsApp AI Assistant with Pabbly Connect
Styling your assistant is essential to match your brand’s identity. In Pabbly Connect, you can customize the appearance of your WhatsApp AI assistant. Choose between light or dark themes, and alter the shape of the assistant’s display to circle, square, or rounded square.
Further customization includes changing background colors, text colors, and button colors. You can also upload profile pictures for both the assistant and the header to enhance visual appeal.
  • Add initial messages that the assistant will send when a chat starts.
  • Decide whether to display or hide the “Powered by Pabbly” label.
  • Create footer text or links for privacy policies or other important information.
These styling options in Pabbly Connect help create a professional and cohesive look for your WhatsApp AI assistant, aligning it with your brand’s image.
5. Assigning Your Assistant to WhatsApp Chats via Pabbly Connect
After creating your WhatsApp AI assistant, the next step is to assign it to your WhatsApp chats using Pabbly Connect. This can be done in bulk or for individual chats. To assign in bulk, navigate to the inbox settings and enable AI auto-reply settings for selected contacts.
For individual chat assignments, select a specific WhatsApp chat in the inbox section. Turn on the assistant button and choose the assistant you want to assign. This flexibility allows you to manage customer interactions effectively through Pabbly Connect.
  • Enable AI auto-reply settings for bulk assignments.
  • Select the contact list from which you want to assign the assistant.
  • Click the save button to finalize the assignment process.
By following these steps in Pabbly Connect, you ensure that your WhatsApp AI assistant is actively engaging with customers, providing timely responses and enhancing their experience.
Creating a WhatsApp AI assistant using Pabbly Connect significantly enhances customer engagement for your e-commerce store. By following this detailed guide, you can set up your assistant effectively, ensuring prompt and accurate responses to customer queries.
