To start using Pabbly Connect, first visit the Pabbly Chatflow website. Enter the URL www.pabbly.com/chatflow in your browser. Once there, you can either sign in or sign up for a free account.
If you are a new user, click on “Sign Up Free” to create an account and receive credits. Existing users should click “Sign In” to access their dashboard. After logging in, you will see all Pabbly applications, including Pabbly Connect, which is essential for integrating your WhatsApp chatbot.
2. Setting Up Your WhatsApp Chatbot Using Pabbly Connect
Once you are logged into Pabbly Connect, navigate to the WhatsApp dashboard. Here, you will need to add your WhatsApp number to your Pabbly Chatflow account. Click on “Add WhatsApp Number” and choose the preferred method to connect.
- Click on “Connect” for the preferred method.
- Alternatively, use a manual token if preferred.
After connecting your WhatsApp number, select the “AI Assistant” option from the left-hand menu. Click on “Add Assistant” to create a new chatbot. Name it, for example, “Home Match Realty,” and click “Create” to proceed.
3. Configuring Your AI Assistant with Pabbly Connect
In this section, you will configure the AI assistant settings in Pabbly Connect. Start by selecting the instruction type from the dropdown menu. Choose the AI agent option, which will automatically populate the required fields.
Next, set the creativity level of the AI responses by adjusting the “Temperature” slider. A setting of 0.7 is recommended for a balanced response. You will also need to enter your OpenAI API key, which can be generated by clicking the provided link.
- Create a new secret key in OpenAI.
- Copy the key and paste it into the API key field in Pabbly Connect.
After entering the API key, click “Update Key” to save your configuration. This step is crucial as it allows your AI assistant to function properly using Pabbly Connect.
4. Uploading Your Knowledge Base to Pabbly Connect
To enhance your AI assistant’s responses, you need to upload a knowledge base file. This can be a PDF or a document containing information about your real estate business. Use the “Upload File” option in Pabbly Connect to select your file from the cloud.
Ensure your file includes all relevant details like pricing, amenities, and frequently asked questions. Once uploaded, your AI assistant will utilize this information to provide accurate responses to user queries.
- Include information about current properties and pricing rules.
- Add customer service details for fallback responses.
After uploading, ensure that your knowledge base is comprehensive so that your AI assistant can deliver detailed and helpful replies to users through Pabbly Connect.
5. Finalizing and Activating Your AI Assistant in Pabbly Connect
After configuring and uploading your knowledge base, it’s time to finalize your AI assistant. In Pabbly Connect, toggle the assistant to make it active. This ensures that it can start responding to user queries on WhatsApp.
Next, you can assign this AI assistant to specific contacts or groups within your WhatsApp account. Go to the inbox settings, select the assistant, and save your changes. This step is crucial for ensuring that the right contacts receive automated responses.
- Enable AI auto-replies for selected contacts.
- Assign the assistant to all contacts for broader reach.
With these settings in place, your WhatsApp chatbot will be fully operational and ready to assist customers in real-time, thanks to Pabbly Connect.
In this tutorial, we explored how to create a WhatsApp chatbot for your real estate business using Pabbly Connect. By following these steps, you can automate customer interactions efficiently.
Utilizing Pabbly Connect ensures that your chatbot is well-equipped to handle various inquiries, providing a seamless experience for your clients.
