1. Setting Up Pabbly Connect for WhatsApp AI Assistant
To create a WhatsApp AI Assistant, the first step is accessing Pabbly Connect. This platform allows you to integrate various applications seamlessly. Start by signing up for a free trial on Pabbly Connect.
Once logged in, navigate to the dashboard where you’ll find options to create new workflows. Pabbly Connect will serve as the central hub for integrating WhatsApp with OpenAI, enabling your AI Assistant to function effectively.
2. Creating Your AI Assistant with Pabbly Connect
After setting up your account, the next step is to create your AI assistant. Click on the “Add AI Assistant” button in Pabbly Connect. Enter a descriptive name for your assistant, such as “AI Assistant for Diagnostic Lab”. This name will help you identify your assistant later.
  • Click on the “Add AI Assistant” button.
  • Enter a descriptive name for your assistant.
  • Select the instruction type as “AI Agent”.
Once you click to create the assistant, Pabbly Connect will automatically generate the necessary instructions for your AI assistant. You can customize these instructions to fit your specific needs.
3. Configuring Your AI Assistant Settings in Pabbly Connect
Next, configure your AI assistant’s settings in Pabbly Connect. Set the temperature to control the creativity of responses; a temperature of 0.5 is recommended for balanced replies. Choose OpenAI as the model provider and select the GPT-4 Mini version for optimal performance.
After selecting the model, you will need to input your OpenAI API key. To obtain this, go to your OpenAI account, create a new secret key, and copy it back to Pabbly Connect. This step is crucial for enabling your AI assistant to generate responses based on the OpenAI model.
4. Uploading Knowledge Base in Pabbly Connect
Uploading a knowledge base is essential for your AI assistant’s functionality. In Pabbly Connect, navigate to the knowledge source section and upload a PDF or text file containing all relevant information about your business. This file acts as the brain of your AI assistant.
  • Ensure your knowledge base file is well-structured and informative.
  • The file size should be less than 90 MB.
  • Upload the file directly in the knowledge source section.
Once uploaded, click “Insert” to finalize the addition. This will enable your AI assistant to provide accurate and relevant responses to customer inquiries.
5. Finalizing Your AI Assistant in Pabbly Connect
After configuring all settings and uploading your knowledge base, the final step is to customize the appearance of your AI assistant. In Pabbly Connect, you can modify the title, subheading, and initial message that customers will see. This customization enhances user interaction.
Once you are satisfied with the design, enable the assistant and click the “Save AI Assistant” button. Your WhatsApp AI Assistant is now ready to assist customers 24/7. Additionally, you can embed this assistant on your website by copying the provided code and pasting it into your website’s HTML.
Creating a WhatsApp AI Assistant without coding is made easy with Pabbly Connect. By following these steps, you can automate customer interactions and enhance your business’s efficiency. Start building your AI assistant today!
